2013 turn signal replacement RF(OEM)
(08-31-2021, 05:41 PM)pekingduck_imp Wrote: Nice catch. That's a weird anomaly. The right front has a $105 retail price, but the left front is $59. Plugs in the same, wire length the same. Only difference is the color of one of the wires - blue instead of orange. Rears are also differently priced, though more closely priced at $56 and $48. Just weird.
Hmmm.. puzzling.
I wonder if the price difference has to do with which side of a motorcycle is more likely to get tip over damage: the right side ? or the left side ?
If the left side is more likely, say due to a higher probability that someone forgets or is sloppy about putting the sidestand down on the left side before letting the bike down, then you'll sell more left side blinkers than right side so you can sell the left for a lower price than the right and still get a fair return on the manufacturing cost ?
Hmmm.. puzzling.
Hmmm.. puzzling.
Parts prices are different for each country/distributor. It has more to do with the fact American Honda doesn't have the manpower to review/fix anomalies like this. Honda Canada and UK show comparable prices from left to right.
Hmmm.. puzzling.
Hmmm.. puzzling.
Hmmm.. puzzling.
No, it's just that Americans are more clumsy than Canadian and UK riders and are constantly dropping their bikes off their sidestands compared to riders in Canada and the UK (ha !)...
That's interesting that the prices would be off like that !
Apart from wiring colour, are the two signal lamps otherwise identical??
Well the lens screw is on the bottom (normal). So if you used the (example) left light on the right, the screw would now be on the top and you would have one screw up and one down.
The wire lengths MAY be different, IDK. I’d have to check the spare ones I have.
The wire lengths is different
Thanks PB.
Thanks. Worth knowing for the future.
  CB1300 headlight bucket replacement spechg 5 364 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 918 01-19-2026, 05:09 AM
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,492 08-16-2025, 05:01 PM
Last Post: bflint
  Rear brake pad replacement LongRanger_imp 39 3,458 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 475 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 745 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 989 04-20-2023, 10:17 AM
  Fuel filter replacement Mafd2_imp 36 2,824 02-11-2023, 01:54 AM
  Replacement Battery dave 54 3,851 02-04-2023, 12:41 PM
