Gear indicator
(04-29-2021, 10:53 AM)gswanson89_imp Wrote: Apologies for trying to resurrect a dead post lol. Mine says 5th anytime I'm in a gear, but still shows blank for neutral, any ideas?
There is a rotary switch that gives a signal so the display can know which number to show. It looks like that rotary switch is not rotating with the gearbox shaft.
Someone had this problem before
edit: found it!
http://cb1100forum.com/forum/showthread....#pid260808
Easy and cheap fix. If it's not this, you'll need a new rotary switch.
(04-29-2021, 11:23 AM)Cormanus_imp Wrote: gswanson, OEM gear selector or aftermarket?
Man, can't believe it took me 10 months to notice I got a reply
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,522 08-16-2025, 05:01 PM
Last Post: bflint
  Broken indicator lens spechg 6 673 04-18-2024, 03:01 AM
  Power source for oil indicator led norton1974_imp 1 276 12-31-2022, 10:07 AM
  Service indicator - unleashed j3gq_imp 6 606 07-27-2021, 03:12 AM
  Rear indicator design problem Mixagon_imp 5 505 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Turn Indicator Switch question Scotty_imp 6 499 09-22-2020, 11:58 AM
  Gear shift indicator stuck on 4 bflint 39 2,599 03-11-2020, 02:46 AM
  Changing indicator lamps max 1 207 12-02-2018, 07:47 AM
  Sometimes Ending Up Between Gears With Gear Indicator Line Blinking 2017CB1100EX-STL_imp 27 1,966 08-03-2018, 12:35 AM
Last Post: apex1_imp
  Motorcycle doesn't start, high oil temperature indicator comes on Saarang_imp 17 1,180 07-20-2018, 07:14 AM
Last Post: SportsterDoc
