Clutch replacement advice
Like any other clutch- it slips a bit on high load / hard accel. But unlike a car that has 1 friction disk in a dry hot environment- the is a stack of numerous layers of disks lubricated by the engine oil.
(06-09-2022, 10:47 AM)Cormanus_imp Wrote: Mine has started to grab a bit. When I put the bike in gear with the clutch pulled in, I can feel it wanting to creep forward. When the engine is hot, it is much harder to get the bike to go into neutral.
Your basket fingers could be worn. I don’t envision you to be hard on the clutch so doubt the metal disks are overheated and warped.
Ah, so when you refer to slipping youre talking about what feels like a dip in pulling power under hard accelleration.
You won’t notice a dip in accel- you will hear the revs go faster than normal in relation to your rate of accel.
Think of driving in snow- accelerate smoothly and all is well. Then put your foot in it a bit too much and the tires loose grip, spin faster than they should and the revs climb. Back out of the throttle a bit and they regain traction. Clutch slip is pretty much exactly the same.
My wife’s car is well known to have a clutch that is ‘just enough’ for a stock car. That being said- I’ve upped the boost pressure on her turbo because she doesn’t drive hard at all. No launches, no shifts during hard accel- so for her it’s fine:
if I drive it and roll into the throttle at highway speed to overtake, say about 3,000 rpm and half throttle or more- the clutch will slip, revs climb and I remember to back out of the gas, clutch grabs, and I continue at less throttle trying to remember not to do that. Smile
Mine does that too ..... I've got over 104,000 miles on it. Yes, original clutch.
Sent from my Pixel 6 using Tapatalk
Welcome to the Forum mattmcuomo1.
I have been aggressive on some past [Yamaha] clutches to get them past 65000 kms before noticing some excessive slippage. That is the "early indicator" Dubs is likely referring to. You will have plenty of opportunity to replace the subassembly and be on your way again Mr. P.
Quote:Mine does that too ..... I've got over 104,000 miles on it. Yes, original clutch.
That’s good miles. How many times have you changed the clutch fluid and bled the slave cylinder?
Well at least all that info helps me to understand what to look out for. That sounds like a pretty odd feeling that would be hard to miss. Cant say ive ever felt a bike do that. Even a properly ancient one.
In terms of excessive clutch "grab", I have experienced that, but not due to clutch plate wear, but because of an overheated clutch/hydraulic system - due to engine overheating. The Honda engine was air-cooled and just wasn't getting what it needed on a still-air, profuse humid summer evening in Toronto during a Caribbean Carnival. Once the engine had a chance to cool down (~30 minutes), the clutch resumed normal behaviour.
To be honest, in this particular case the "early warning" was quick - in terms of minutes.
Funny story- in my youth my friend had an old well used and abused dirt bike from the 70’s.
He had it out on the road, and was dropping the clutch to break the rear tire loose for burning rubber. Then I see / hear him doing it over and over again- then looking at the bike like something was wrong. I walked over- thinking he smoked the clutch- nope- the front sprocket teeth were completely worn away and the chain was just spinning on the remains. [Image: 2cbe9850b64237f061e5a20e09ca984c.png]
(06-09-2022, 11:49 AM)PowerDubs_imp Wrote: Funny story- in my youth my friend had an old well used and abused dirt bike from the 70’s.
lol - on an ADV forum I have seen a few "proud" images of that.
They seem to pride themselves replacing sprockets often (front and rear).
  Advice please--maintenance on new to me CB LucienLeFranc 11 826 06-24-2026, 01:34 PM
  CB1300 headlight bucket replacement spechg 5 390 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,028 01-19-2026, 05:09 AM
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,322 12-24-2025, 11:14 AM
  Rear brake pad replacement LongRanger_imp 39 3,780 05-03-2025, 10:45 AM
Last Post: Delphisa
  Replace clutch Lever Davidjill_imp 10 1,010 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,085 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 251 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Fork Pipe replacement suggestions danieljrmurray_imp 3 519 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
