Front sprocket bolt cant be moved
(03-08-2023, 09:45 PM)Razor_imp Wrote: Just for kicks: set your electric impact to tighten, and give it a couple of seconds, then immediately switch the impact to loosen and see if it budges. Another alternative is to use a hand impact tool. Only downsize is it will put stress on the countershaft bearing. If you’re willing to go this route; HF sells them. Make sure to get the 1/2’ drive set. That way you can use an impact socket. Good luck!
Link to the HF hand impact. These come in handy for other jobs too.
https://www.harborfreight.com/6-bit-impa...64812.html
I do actually already have that, I was using it previouosly to deal with ancient screws that i'm worried about stripping out.
Does that actually have a better chance at working than a power tool?
(03-08-2023, 11:59 AM)PowerDubs_imp Wrote: Watch a few of these videos... and there is a lot to learn. There are reviews of electric stuff- and real world tests and comparisons.
https://www.youtube.com/@TorqueTestChannel/videos
Got a Harbor Freight near you? If not- Amazon or Ebay will work... or you can probably find something used that will do the job on your local Facebook Marketplace or Craig's List..
unfortunately, for the money any new tool will cost me I could just about pay the shop an hour of labor to swap it out for me, which It looks like is exactly what's going to happen. I'd rather do that than risk making it worse with my continued fumbling.
(03-08-2023, 09:12 PM)redbirds_imp Wrote: I replaced the chain and sprockets on a Kawasaki few years ago and had this same problem. Tried heat, breaker bar and penetrating oil. Finally borrowed a friend's pneumatic impact wrench and it was off in a flash.
Useful to know RedB.
(03-08-2023, 09:27 AM)misterprofessionality_imp Wrote: What does one do when one cannot turn the bolt that fastens the front sprocket in place? Ive tried impact wrenches, cheater bars, nearly broken a socket.....what am i supposed to do?
This is actually the second time ive changed a front sprocket. It was hard but it moved the first time. This time its like its welded on.
Have you considered if its a reverse thread?
Left hand threads are common on spining things!
I don't think I've ever heard of a front sprocket like this having a reverse thread....the first time I removed it i don't believe it had a reverse thread. if anybody else can confirm that or tell me different i'll take the L, but i'm pretty certain it doesn't have a reverse thread.
(03-09-2023, 12:06 AM)misterprofessionality_imp Wrote: I don't think I've ever heard of a front sprocket like this having a reverse thread....the first time I removed it i don't believe it had a reverse thread. if anybody else can confirm that or tell me different i'll take the L, but i'm pretty certain it doesn't have a reverse thread.
Service manual torque table says: thread dia. 10mm, torque 40 lbf.ft and the remarks column is empty. The later means it’s not a left handed thread. Also not word one on “being left” on page 3-21.
Of course jto is right with his remark BUT it’s a matter from where you look. When our engine pulls the sprocket forward (call this a right turn as seen from the inside) it tightens the screw.
You've had it off before? The plot thickens...
Did you tq to spec upon reassembly?
40lb/ft is half of what I tq my lug nuts to.
I did, assuming i used the torque wrench correctly. that was maybe 4 years ago now though.
Usually left hand threads are on a right hand side chain front sprocket.
+1
(03-09-2023, 01:26 AM)m in sc_imp Wrote: ride up to rock hill sunday i'll zip that thing off in a hot minute. Banana
def not reverse thread though
I was just there last weekend Dodgy
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,004 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,220 07-30-2024, 10:05 AM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,193 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 964 01-03-2022, 08:30 AM
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 4,028 03-07-2021, 09:32 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 700 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,279 10-15-2020, 02:13 PM
Last Post: max
  Another chain and sprocket question bflint 20 1,488 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,657 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Engine mount bolt torque value TCinNC_imp 43 2,607 07-31-2020, 05:00 PM
Last Post: treedoc_imp
