Threads: 43
(08-11-2022, 12:43 AM)Lord Popgun_imp Wrote: Here is a place in the UK that sells them for the ‘17 : https://picclick.co.uk/Honda-CB1100EX-RS...53683.html
However, Houtman said the ones he got from somewhere in the UK did not work on his RS. YMMV
Would anyone know whether the EX / RS would indeed need two O2 sensor eliminator plugs, or is one of these plugs (connectors) enough ?
Thanks
Threads: 115
(08-11-2022, 04:46 AM)The Gecko_imp Wrote: (08-11-2022, 12:43 AM)Lord Popgun_imp Wrote: Here is a place in the UK that sells them for the ‘17 : https://picclick.co.uk/Honda-CB1100EX-RS...53683.html
Thanks
Thanks
I had two of them on my 2017 EX , did not work , two on my 2014 DLX worked perfectly .
Likes Given: 1,004
(08-11-2022, 03:22 AM)Lord Popgun_imp Wrote: Sorry about that. I mis-remembered the thread.
NO need to apologize, MiLord
Threads: 43
I would assume that different ECU/s could require different plugs. So if Houtmanone tried to use a 2014 O2EP on a 2017 EX that may have failed for that reason. But I would still try to understand whether the EX / RS would indeed need two O2 sensor eliminator plugs, or is one of these plugs (connectors) enough ? Sales person says one needs two, but I'd rather get a confirmation from the board.
Thanks
Threads: 125
If the ECU has / monitors 2 ECU then logic dictates you need to fake 2 ECU bypass plugs.
Threads: 43
(08-12-2022, 08:33 AM)PowerDubs_imp Wrote: If the ECU has / monitors 2 ECU then logic dictates you need to fake 2 ECU bypass plugs.
That is of course true IF "the ECU has 2 ECU", whatever this means ...
Threads: 125
Yea- that guy was probably typing on phone while drinking in garage. <— says the guy who is typing on phone while drinking at beach.
Threads: 12
What are the benefits of using O2 eliminators?
Threads: 125
Smoother low rpm low throttle - so you will notice when in parking lot / driveway type riding.
Threads: 12
(08-18-2022, 01:10 AM)PowerDubs_imp Wrote: Smoother low rpm low throttle - so you will notice when in parking lot / driveway type riding.
thank
