2014 CB1100 Right crankcase cover
Not 100% sure, but I think we had a British bike with Lucas 6V ignition system and 12V battery/lighting??
Also an old/1970 Lambretta 150/175cc had a Magneti-Marelli system with many problems.
Undecided
Getting back to the Cover. In the service manual it is called the right crankcase cover.
But ignition cover works for me. There are 2 dowel pins to hold it in position. Just banging on the side of it with a mallet is not going to knock it off. It may be “glued” on good or the dowels are stuck. Some prying may be necessary, but be careful not to mess up the cover or mating surface.
One dowel is at the top front between the 1st 2 bolts clockwise from the sensor. The other is diagonal across from it (bottom rear) between bolts 2 and 3 counter clockwise from the sensor.
If you have a manual it is shown in section 17 (ignition section)
Thanks, Lord. Didn't know about the dowels. Not sure I want to do any prying. Last time I tried, the engine was cold. Perhaps hot engine may help get it loose.
No need to drain the oil before you remove the cover. Just lay the bike down on the opposite side and all the oil will stay in the engine when you remove the cover. ROFL
(06-01-2023, 01:32 AM)TX Silver_imp Wrote: No need to drain the oil before you remove the cover. Just lay the bike down on the opposite side and all the oil will stay in the engine when you remove the cover. ROFL
Do not laugh Smile
I was 2000 km from home and in another country and my clutch cable "hook" slipped off the cable.
The whole successful repair took 2.5 hours and we arrived home safely.
Beer
Do not laugh Smile
Beer
Certainly marginally better than the cable end-nub snapping off. That created alotta grief for a Yamaha owner, and the summer hot, humid brilliant sunshine did not help either.
Do not laugh Smile
Beer
Do not laugh Smile
Beer
Kinda been there, but snapped cable a long time ago. No way to fix and had to get home. Riding and stopping with no clutch wasn't that bad. Getting rolling to get it into gear was tiring.
Was before cellphones or I would have made a few calls.
  Right Crankcase Cover missing from service manual? bflint 4 612 07-30-2025, 11:55 AM
Last Post: bflint
  Left Side Crankcase Gasket Part number. jbird06_imp 1 302 03-26-2024, 08:56 AM
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 550 08-04-2022, 10:10 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 601 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 935 08-05-2021, 02:01 AM
  2014 Right Side Cover--Red eddi0_imp 12 1,076 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  CBS COMBINED BREAKING SYSTEM in CB1100 ex 2014 ?? Alfgaxatico_imp 4 422 12-26-2020, 08:55 AM
Last Post: 17-CB-002
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,234 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 784 04-13-2020, 05:47 AM
  Colour code for grey crankcase Mabel_imp 10 1,073 08-27-2019, 01:17 AM
Last Post: Frulk_imp
