CBS COMBINED BREAKING SYSTEM in CB1100 ex 2014 ??
CBS Combined braking system. Hello ; it is incorporated in the 2013 models; when you brake with the rear brake ... But in the 2014 model ???? is still maintained ????
Enviado desde mi iPhone utilizando Tapatalk
(12-26-2020, 08:21 AM)Alfgaxatico_imp Wrote: CBS Combined braking system. Hello ; it is incorporated in the 2013 models; when you brake with the rear brake ... But in the 2014 model ???? is still maintained ????
No , it is not .
Thanks ... I not know why ; is not ...
The 2013 ABS model had combined braking. Only that model.
One can easily identify the "Combined ABS" system just by looking at both front brake calipers brake line connection.
"Combined" ABS has independent/separate brake hose connection at the caliper, while the "Regular" ABS has both calipers brake hose connected together behind the horn.
Regards
Alain
  2014 CB1100 Right crankcase cover msundst_imp 16 1,288 06-03-2023, 06:09 AM
Last Post: TX Silver_imp
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 646 08-04-2022, 10:10 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 655 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,070 08-05-2021, 02:01 AM
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 924 04-13-2020, 05:47 AM
  Type of fuel injection system? dave 3 360 02-09-2019, 04:12 AM
  original alarm system Volchkoff_imp 24 1,769 12-20-2018, 10:16 PM
Last Post: FLYTYM_imp
  Has anyone replaced bearings in their front wheel on a 2014 CB1100 ? Searcher_imp 0 188 05-30-2017, 07:16 PM
Last Post: Searcher_imp
  Build your own 2014 CB1100 Deluxe LongRanger_imp 4 399 03-26-2017, 01:27 AM
Last Post: BestStandard_imp
  CB1100 2013/2014 REAR WHEEL INTERCHANGABLE? Searcher_imp 5 429 10-20-2016, 12:29 AM
Last Post: Jim_imp
