Fuel Pump Alternatives
Thanks for the feedback Sam, much appreciated here on the forum for the benefit of all who read these posts and want to know what the outcome is.
And Popgun's tip about the blocking of the vent hose ( if the fuel tank has been off the bike ) is worth checking out too, you could do that by simply opening the fuel tank filler cap and blowing in it to see if the vent is clear.
Often it's something simple, but not always simple to find, cheersExcited
(07-01-2023, 08:26 AM)Lord Popgun_imp Wrote: On the ST1300 board members have used aftermarket pumps. BUT, and this is a big one, the fuel tubing on them deteriorates rapidly, leading to another job. And getting to the fuel pump on an ST1300 is a major PIA.
Anyway, what they do if source the aftermarket pump and not use the tubing that comes with it, using good or OEM tubing.
I suggest you do the same if you find the pump.
OTOH, we have had few pump failures noted on the board. These pumps do whine. If you put your kill switch in the kill position and turn on the ignition you can hear the pump come on for a couple seconds and then shut off. It isn’t that quiet.
If it were me and I thought the pump was bad, I would do a flow rate test and pressure check.
Also, just taking a shot here, if you have had the tank lifted, lift it again and ensure the vent hose is not kinked or mashed, etc.
More a question than a suggestion: when I read pump are whining, could it be that there is a lub problem? If Honda uses good tubing and other parts to accommodate modern fuels with more or less Ethanol, but hasn’t spend too much time and effort on the pumps, then using too much E85 or similar could cause these problems. It might also explain why others can do 100k miles without problems? Nonsense?
Not supposed to use E 85 in a CB 1100. It's only approved for up to 10% ethanol.
(07-11-2023, 05:33 AM)The ferret_imp Wrote: Not supposed to use E 85 in a CB 1100. It's only approved for up to 10% ethanol.
I know, what I meant is one could choose even the 10% ethanol variety ost of the time, and somebody else never does .... and this could explain the different results ???
  Fuel pump, yes really. GUNFTR_imp 13 1,211 01-02-2024, 01:11 AM
Last Post: SportsterDoc
  Fuel pump noise? Ben70_imp 15 1,025 07-16-2022, 12:22 AM
  fuel pump automotive equivalent battaglioa01_imp 0 207 11-19-2021, 02:11 AM
Last Post: battaglioa01_imp
  fuel pump whine battaglioa01_imp 2 356 11-18-2021, 05:30 PM
  Bad fuel pump- jdgrego1_imp 33 2,729 11-20-2020, 03:07 AM
  Intermittent fuel pump QUINTtastic_imp 4 451 06-15-2019, 12:17 PM
Last Post: QUINTtastic_imp
  Fuel Pump problems ? sharkyo4_imp 11 834 07-06-2018, 10:02 AM
  Torque Specs for fuel pump Mscb1100_imp 5 568 03-13-2018, 03:38 AM
Last Post: Flytech99_imp
  Oil Pump Losing Prime Ulvetanna_imp 10 779 08-24-2016, 10:56 AM
Last Post: 12cb96vfr_imp
  fuel pump connector wiredgeorge_imp 10 614 12-13-2015, 10:30 PM
