engine light
If it were my bike, I first would check the DTC and then act accordingly.
I have never deleted any DTC without checking its description.
(09-09-2023, 01:18 AM)Alain Lee_imp Wrote:
(09-05-2023, 09:37 PM)Lord Popgun_imp Wrote:
(09-05-2023, 12:14 PM)Cormanus_imp Wrote: Came with the Ring, did it? Tongue
That thing does come in handy once in a while.
Good Day Max, how come your CB comes with "HISS" system, was that CB imported from Japan or other countries?
Max? HISS?
Hey Alain, wuz goin' on?
If not mistaken, Max’s CB is equipped with HISS anti theft system
(09-09-2023, 03:48 AM)peterbaron_imp Wrote: If not mistaken, Max’s CB is equipped with HISS anti theft system
... and has to do with thread "engine light" how?
Max is a busy man. So I will respond that, yes, his bike was imported direct from Japan. I will add that the CB1100s sent to Australia and New Zealand between 2010 and 2012 were all equipped with the HISS.
(09-05-2023, 09:08 AM)Lord Popgun Wrote: Tpo,
It is not hard to do but there is a little procedure.  You will need the SCS service connector (a shorting plug) or a paper clip or jumper wire to short 2 pins on the DTC connector.
We cannot post copyrighted material here so if you will PM me your email address I will send you a pic of the service manual that shows and tells and shows you the simple procedure.  And I will tell you which wires to short as the procedure uses the SCS connector.  And no one seems to have one, except me Big Grin
dougwene@yahoo.com
I have my first check engine light also.  Sorry to bother.   Never owned a motorcycle with a computer before.
For educational puropse read the entire thread from post #1
You need to know the dtc, fix it acordiangly prior earasing it... any driveability concerns???
Your bike  is a 2017EX, I think is a red-4 pin connector under L-side cover / OBDII ready, I have and use a dtc scanner/reader for motorcycles.
General info for a CB1100 is listed below:
https://www.youtube.com/watch?v=iwSllBQNsWc
https://smartmoto-electronics.com/smart-...ch-dmt-003
https://www.google.com/search?q=how+to+r...e&ie=UTF-8
https://www.youtube.com/watch?v=oQR43VkCbpc
Others like pekingduck, max and MiLord may chime in and correct me if I was mistaken....
P.S. Oh boy, 8-9 years old and only 1600 miles, you need to ride this beautiful machine Exclamation
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Photo First Check Engine Light Ever on a Bike doug1976 2 229 01-14-2026, 06:47 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,262 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 431 07-03-2023, 10:18 PM
   Engine light Blinking tory_imp 25 1,805 12-04-2019, 10:38 PM
  check engine light stays on, on my 2017 Houtman_imp 51 3,418 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  running light and brake light Ennsync_imp 3 430 01-02-2019, 11:24 PM
  Check engine light/codes Carguy1959_imp 17 1,149 08-24-2018, 03:00 PM
  Oiltemp,check engine and hiss light thomasdebess_imp 7 568 09-12-2015, 10:28 AM
Last Post: flynrider
  Engine quit at stop light sanoke_imp 41 2,629 08-05-2015, 11:30 AM
Last Post: sanoke_imp
