Chain or sprocket problem ?
Thanks guys, really appreciate.
Chains and sprockets...
I was just cleaning things up (once a year whether it needs it or not) and looking at my chain and sprockets. Everything looks fine to my untrained eye but that means nothing. I have right around 32k miles on her. The teeth on the sprockets aren't hooked or overly sharp. The chain adjustment seems to have more room to grow.
So, how do I know when it's time for some new parts and when that time comes, where do I find parts? I have been googling parts and as far as I can find no one has OEM sprockets in stock. Lots of after market stuff to choose from but I would rather have the real thing.
Thanks in advance!
Most likely the OEM parts are best for our CBs, exept the tires Confused
At 41K miles/no commuting, I already replaced front+back sprockets with chain/RK and rubber cusions as a set. Why, because they are constantly working together.
Chain and sprockets received midium- service and somtimes were ran 3K miles without any service during my Maritimes trips and including 300+ miles while raining per trip = no lube.
Minimum I needed to replace was the chain = 4 kinks/tight spots and vibration in 4th gear, the sprockets and rubber cusions would last much longer.
Now, at 74K miles I only replaced the chain/RK. I inspected the sprockets and these still look good. Also, I sevice my drivechain ass-y more often, every +- 500 miles with 80W90 synthec gear oil and wax combination RIGHT after my ride when the chain is still warm. This ensures proper and deep chain penetration!
I lube my chain after every wet ride, even my if ride was short!
For reckless riders, lacking services, harsh conditions, short distances/commuting, parts replacement is needed more often.
Remember, proper and adequate service gives your bike and its parts greater longivity.
For camparison, I drive my car/ATM 3x/week to work for 32 miles each way and 3/4 distance is hwy driving. I need all around pads and rotors every 85-95K miles due to wear and vibration when braking.
My wife drives hers to work 7 miles each way, no hwy. She needs her all around brakes to be replaced ever 50-60 K miles mostly due to corossion and vibration, some pads still left.
Both cars are garaged.
How and where one rides, road conditions and proper service intervals make a big difference.
So if you don't know when is time for some new parts just submit pics and our forum's experts will advise you acordiangly to make your decision.
Good luck.
Beer
"Most likely the OEM..."
No problem with options and final decision.
Wink
The chain slack according to the service manual is 1-1.4” Yours is slightly out of spec and is on the loose end. Is it possible the chain is “clanging” on the chain guard?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 122,233 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,170 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,154 12-23-2024, 04:47 AM
  O ring chain problem Mixagon_imp 7 683 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,116 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,748 03-13-2023, 12:18 PM
  May have a problem the Ferret 12 863 01-20-2023, 04:53 PM
Last Post: max
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,305 11-29-2022, 07:49 AM
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,959 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,569 10-08-2022, 09:18 AM
