triple tree Rust (not the Fork Brace)
I've had rust under the chromed triple trees of both my Fury and my long-gone 1100 Shadow. Not nice. When I see it I usually remove the rust with a chrome/cleaner/wax. This seems to keep it at bay for while (but I haven't really obsessed over it enough to know for sure).
Seems to be a common problem. Mine started to show rust after about 12 months. Painted some rust converter over it and the touched it up with some new silver paint. Now I have noticed that the oil cooler pipes have developed rust where they connect to the cooler. The engine fins are showing signs of paint peeling now so I will need to touch them up as well.
Mine did too, it started on the clamping surface then bled up under the clear coat.
http://cb1100forum.com/forum/showthread.php?tid=3263
I've been using S100 on the new bike and is working great so far.
(12-06-2014, 04:04 AM)LiveToRide_imp Wrote: About 6 months after buying my CB the fork brace started rusting. I'm in the Pacific northwest and it is a bit moist here and I'm by the ocean but the bike is kept in a dry shed. Honda replaced the brace and here it is about 9 months later and it's rusting just like the 1st one. I haven't been back to the dealer yet to see if they will do anything about it this time. I've started keeping a coat of WD40 on it hoping it will keep it from getting worse. Anyone else run into this issue?
Remove rust as described in the posts above and then spray with [url=http://www.nocorrosion.com/corrosion-control.htm]Corrosion Block.
Problem gone.
I discovered a spot of rust on my lower triple-clamp - is this what you're calling a fork brace? It was right directly next to and touching the fork tube so I assume galvanic corrosion may be the culprit. I rubbed it off with my finger. I live in San Diego, but about 5 miles from the ocean, and the bike is garaged at all times.
ACF50 is about the best rust preventative you can get it will stop existing rust in it's tracks. It is particularly good in areas like the triple trees.
Pete
(12-21-2014, 08:20 AM)VOZZA_imp Wrote: ACF50 is about the best rust preventative you can get it will stop existing rust in it's tracks. It is particularly good in areas like the triple trees.
Pete
It is. And the link to that product is in post#14.
  Rust on mudguards Classico_imp 15 1,095 07-11-2022, 06:22 AM
Last Post: Classico_imp
  Rust and Corrosion dave 71 4,848 02-26-2022, 02:22 PM
Last Post: hondadownunder_imp
  Rust on tank from crash calipo223_imp 6 614 09-17-2020, 05:06 PM
Last Post: jtopiso_imp
  New Triumph Triple Middleweight coming pekingduck 10 780 08-29-2020, 05:15 AM
Last Post: Bheezy27403_imp
  Triple Trouble Ack-CB11_imp 10 735 01-15-2019, 12:48 PM
  Tree fell on my garage curlyjoe 31 2,030 10-20-2018, 10:52 AM
  Rust dave 1 224 04-02-2016, 02:13 AM
Last Post: Ghost_diver_imp
  Rust on lower fork bracket LiveToRide_imp 134 10,156 05-12-2015, 05:23 AM
Last Post: Elipten_imp
  Rare triple CB1100 sighting in the wild willsmith_imp 22 1,336 06-12-2013, 02:19 AM
Last Post: willsmith_imp
