[SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack?
rdprdp01 Online
Pleasanton, CA (USA)
Threads: 201
Likes Received: 944 in 394 posts
Likes Given: 1,273
RE: Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack?
(06-17-2026, 02:30 PM)LucienLeFranc Wrote: Anyway, maybe you could use similar clamps onto the rear rack to hook yours up?
Very creative and inspiring. I love my SW-Motech Top Case and my OEM Rear Rack. With your creativity and vision, you may have solved the problem I was failing to solve: how I can mount the W-Motech matching side cases and preserve everything else. Thank you! David
2017 Honda CB1100 EX
06-20-2026, 10:41 PM
JRD Offline
Pro-Moto, Anti-Fascist
Santa Cruz, California, USA
Threads: 11
Likes Received: 48 in 19 posts
Likes Given: 72
Okay, they are mounted. It is done and I have a definitive answer:
First thought, best thought. You have to just mount them outside of the rear rack. The screws that were used to mount the rack are not long enough with the added width of the side mounts, so you need to buy four new screws. They all need to be 8mm x 1.25mm. Two of them should be 90mm button top; two of them 80mm socket flat head.
The mounts come with arms to relocate the blinkers, but my blinkers were already out of the way, down by the license plate. Not sure if that is because H&B is a German brand and this is a Euro vs US set-up, of if my bike’s previous owner moved the blinkers when the rear rack went on. But either way, the relocation arms are unneeded and unsightly, so I’m just took a hack-saw to them and cut them off to streamline the look a bit.
07-09-2026, 05:40 PM
Threads: 349
Likes Given: 1,101
The signals must have been moved by the PO. Heaven knows why; they work all right in their original position with the rack on.
Having uploaded the photo, did you click "Insert in post"? Or is the original photo file larger than 2MB?
07-09-2026, 06:55 PM
LucienLeFranc Offline
Portlandish Oregon
Threads: 11
Likes Received: 96 in 44 posts
Likes Given: 101
Congrats on a successful install!
Hoping you can ultimately post pictures.
Do you think the other H&B rack would mount similarly?
https://www.motomachines.com/hepco-becke...-from-2013
Or not really able to tell?
Motoloves of my life:
Heart
2014 CB1100 DX
2016 XR650L
07-09-2026, 07:19 PM
JRD Offline
Threads: 11
Likes Given: 72
I have read that that those ones *are* compatible, but I don’t know for sure. I didn’t go that direction because the C-Bows would work with the hard cases I already have.
07-09-2026, 07:38 PM
  How to Source a Rear Rack for a CB1100 rdprdp01 5 774 11-18-2025, 01:52 PM
  Hepco & Becker luggage Nitro_imp 12 1,228 03-20-2024, 03:37 AM
Last Post: Mitch_imp
  Hepco Becker Replacement Key tomcat_imp 5 700 08-10-2023, 03:20 AM
  Flipping the handle bar mounts around 1985CB450_imp 4 535 10-11-2022, 05:21 PM
Last Post: Mixagon_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 833 04-08-2022, 03:41 AM
  hepco becker side back C system alexzanutto_imp 16 1,802 07-31-2021, 07:34 AM
  Rear Rack for 2013 CB1100 Closeout Redbird_imp 4 567 07-21-2021, 11:34 AM
Last Post: tj_gee_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 5,111 12-12-2020, 11:51 PM
  Hepco Becker plus Honda OEM racks Mitch_imp 6 944 06-28-2020, 01:50 AM
Last Post: andyoz_imp
  Corbin seat with Hepco & Becker luggage Marcus_imp 10 998 10-25-2019, 11:48 PM
Last Post: mdharne_imp
