01-03-2026, 07:33 PM
PB, I'm working on getting a set of used 2017 EX gauges operational for Deano, waiting for a used eBay connector plug to test the meter assembly
on my bike.
m-txd/rxd wire (white) ecu to instruments communication
(01-03-2026, 07:33 PM)pekingduck Wrote: PB, I'm working on getting a set of used 2017 EX gauges operational for Deano, waiting for a used eBay connector plug to test the meter assembly on my bike. Wow, that is a lot of Honda, just to get that plug, but I guess it is the only way to be sure it's the right one. I had ordered something similar for this RS from Aliexpress, but the slide and grooves of the body did not match up. I will be out in the garage to photo what I have here as wiring & connections for the gauges (damaged off RS) Many thanks, Deano
01-13-2026, 07:52 AM
Hello all,
I am getting desperate now. I need to find a set of instruments for a CB1100RS as mine were smashed in an accident. I tried replacing with CB400 vtec Superfour's, but out done at the end by the white comms wire, from the ECU. As I can't get help on how to overcome that issue, now looking to buy a set of clocks (instrument assembly) complete. Can anyone help, any where please, anyone breaking a CB1100RS? Many thanks, Dean
01-13-2026, 01:48 PM
Are you not able to get replacement parts from Honda?
Sometimes the road not travelled is best left that way. (Jane Goodall)
01-13-2026, 02:04 PM
(This post was last modified: 01-13-2026, 02:16 PM by pekingduck.)
Only the outer case coverings are available. The speedometer, tachometer, digital panel, main circuitboard, harness, and the big inner white casing everything bolts to are not available.
Bummer. I thought Honda kept spares for 10 years?
01-13-2026, 06:04 PM
I already sent cluster request to my Honda / Canada friend and awaiting his response.
"Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan® '14 CB1100 DLX, s/n 170, 42K kms - FOX® '14 CB1100/ABS, 134K kms - sold '13 CB1100/c-ABS - 56K kms - sold *Grand Chancellor* (01-13-2026, 01:48 PM)Cormanus Wrote: Are you not able to get replacement parts from Honda? Yes, for around $1,500, which is crazy money. Someone out there must be able to help without me needing to spend that. With the CB400 Vtec Superfour assembly on there, I had figured the speed, revs, fuel etc etc....just came down to that White comms wire, rendering all my hours of work useless, which sucks. (01-13-2026, 06:04 PM)peterbaron Wrote: I already sent cluster request to my Honda / Canada friend and awaiting his response. Many thanks for your help.
01-14-2026, 05:35 AM
(01-14-2026, 04:59 AM)deano Wrote:(01-13-2026, 01:48 PM)Cormanus Wrote: Are you not able to get replacement parts from Honda? That's a lot of dough.
01-14-2026, 08:42 AM
(This post was last modified: 01-14-2026, 11:29 AM by peterbaron.)
(01-14-2026, 04:59 AM)deano Wrote: Yes, for around $1,500, which is crazy money. Can you provide the correct P/N for the cluster you need , is it 37100-MGC-CC2 ?G You have a 2017 Honda CB1100RS? Send me your VIN by pm or email. In your case, I operate on an international market, so is easier for me to provide the correct part number, some sites request VIN to avoid errors! One answer so far from a dealer, Canadian site is listed: Gauge Cluster, 37100-MGC-CC2, C$1253 +13% tax + S&H, back order March 11-24 Expecting more info from Europe...
'24 Kawi Z650RS - Hooligan® '14 CB1100 DLX, s/n 170, 42K kms - FOX® '14 CB1100/ABS, 134K kms - sold '13 CB1100/c-ABS - 56K kms - sold *Grand Chancellor* |
« Next Oldest | Next Newest »
| M-TXD/RXD wire is disconnected | deano | 1 | 184 |
01-01-2026, 06:40 AM Last Post: Cormanus |
| Wire Colors for Signals, Tail Light | RedRoevr_imp | 10 | 721 |
05-01-2022, 06:23 AM Last Post: Charlie Bravo_imp |
| 2017 EX Tail light wire channel access | TXBikerGuy | 8 | 744 |
07-26-2020, 06:57 AM Last Post: TXBikerGuy |
| Theft Attempt - Cut Wire | ishouldbuyatacotruck_imp | 17 | 1,280 |
07-05-2019, 04:34 PM Last Post: Guth_imp |
| Trigger wire under seat for fuzeblock | Jeya_imp | 14 | 896 |
08-17-2017, 03:54 AM Last Post: Lord Popgun |
| White specks in engine oil | Roper_imp | 17 | 1,177 |
02-09-2017, 10:52 PM Last Post: ClassicVW_imp |
| Which wire to tap for GPS power? | Inhouse Bob | 32 | 2,086 |
07-19-2016, 07:32 PM Last Post: Cormanus |
| wire color | gcarper_imp | 1 | 299 |
06-09-2013, 07:30 AM Last Post: Lord Popgun |
