wheel swap cad cnc lazer reluctor for speed sensor
Likes Given: 1,015
RE: wheel swap cad cnc lazer reluctor for speed sensor
Bummer. I've looked for threads on converting to 17" wheels here and on the old forum, but I can't find anything that's really useful. What I did find suggested it was a difficult project.
10-21-2025, 08:55 PM
1973cb750 Offline
All Tuned Up
Edmond Oklahoma
Threads: 13
Likes Received: 79 in 49 posts
Likes Given: 45
(10-22-2025, 04:53 PM)m in sc Wrote: anything can be done, just depends how much access to equipment you have.
Personally, on this bike, i dont see the benefit.
In this case the Cush drive would have to be cnc d and im not putting that kind of money in it maybe i can score some res wheels
2014 Cb1100 STANDARD #2061  ECU flashing.    Biker        https://www.facebook.com/cj.h.pfeiffer
10-22-2025, 05:36 PM
Website Find Reply
1973cb750 Offline
All Tuned Up
Edmond Oklahoma
Threads: 13
Likes Given: 45
m in sci put some ex500 mags on a 72 h2/H1 hybrid years ago for a friend, and had to mill the carrier hub into the wheel to make the offset work, like said, it can be done, did it on a j head.  I just don't see the real benefit of doing this (or what tim did for that matter).  you could cut one down, make the 'fingers' for the cush, and tig em in as well. just a thought.  but i love doing stuff of this nature so...
the benefit would be tire choices also looks also you would have to add to the wheel not mill it shallower or have a new drive hub machined
10-26-2025, 04:06 PM
Website Find Reply
1973cb750 Offline
All Tuned Up
Edmond Oklahoma
Threads: 13
Likes Given: 45
(10-28-2025, 05:51 AM)m in sc Wrote: how far off is it? you can use a carrier adapter and move the sprocket out pretty easily. rebel gears in Tennessee (highly recommend)  made one for the RD to bring the rear sprocket out about 10mm when i built custom wheels for is using a european rear disc hub, then putting on wide spoked wheels.  they can do further though.  i was able to get an offset front sprocket and they did the rear carrier adapter. been on for 17? years or so zero issues.
More than a inch witch would put the sprocket far left of the Cush drive bearing and cause issues i have a place to make a space no problem it’s the geometry of where the sprocket ends up in correlation with the drive bearing would laterally stress the bearing too much leading to premature failure
10-28-2025, 05:56 AM
Website Find Reply
  Wheel Chocks DAC 8 810 07-22-2023, 10:23 AM
Last Post: DAC
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,378 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 1,895 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 892 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,444 03-16-2022, 07:48 AM
Last Post: outback_imp
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 380 12-04-2020, 12:35 PM
Last Post: 17-CB-002
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,614 06-05-2020, 12:35 PM
Last Post: michael1954
  Houtman's new wheel chock The A-man 14 1,082 07-04-2019, 07:05 AM
  modifying wheel trim misterprofessionality 18 1,481 05-14-2019, 02:49 PM
  cb1100 RS wheel conversion misterprofessionality 34 2,596 04-26-2019, 03:59 PM
