Sissybar/backrest info (from sidecar pics)
Bbref36_imp Offline
Threads: 14
RE: Sissybar/backrest info (from sidecar pics)
(08-21-2013, 11:14 AM)CB4ME_imp Wrote: Get long longish bolts and use one of those small hacksaws with thin blades and a fine tooth file to cut down and debur to achieve a perfect size. Use a vice to make the cut.
That's what I was thinking. Thanks again
08-21-2013, 11:38 AM
Buffalohead_imp Offline
Threads: 10
Put a nut on before you cut the bolt. After cutting, remove the nut and the threads will be perfectly normal. Sometimes when you're filing, you can get a bit of a flat spot. Removing the nut makes it straight. It ensures the threads will be de-burred too. It always works for me.
Sometimes, when you have something that is to be bolted on, but you would rather have studs, you can use the nut to cut the head of the bolt off and make a stud by cleaning up the threads.
08-21-2013, 01:30 PM
pwyakjr@stny.rr.com_imp Offline
Threads: 1
received the jardine and the factory backrest today. I have some ideas. how about posting some pics on how the two go together??? thanks
09-03-2013, 12:15 PM
Threads: 10
(09-03-2013, 12:15 PM)pwyakjr@stny.rr.com_imp Wrote: received the jardine and the factory backrest today. I have some ideas. how about posting some pics on how the two go together??? thanks
Do you mean the Jardine backrest and the factory rack?
I plan to get Mike to take some pics of the details in the next few days.
09-03-2013, 12:22 PM
Threads: 1
yes. factory rack.
09-03-2013, 09:27 PM
CB4ME_imp Offline
Threads: 183
Here's a picture of the Jardine mini and the factory rear carrier on an amatuerish but solid mount.
I'll be interested in what Mike did and what you come up with.
[Image: 2e89707199d8c2d8d681d90ff239b5f3.jpg]
09-03-2013, 10:40 PM
Threads: 1
yea that is what I was thinking. i know where i can get some stainless steel, i'm sure after i'm done i can polish it up nice. i just installed the Over crash bar boy does that look nice. buffalohead stated mike did his installation without the stainless triangle, i wonder what he did???? i just read somewhere online the the cb1100 was voted the best new motorcycle of 2013.
09-08-2013, 11:16 AM
Threads: 10
Pwyak, Mike keeps forgetting to bring his camera. I will do my best to get some pics. Mike's is a clean installation.
09-08-2013, 01:45 PM
Threads: 698
Likes Received: 621 in 278 posts
Likes Given: 789
(09-03-2013, 10:40 PM)CB4ME_imp Wrote: Here's a picture of the Jardine mini and the factory rear carrier on an amatuerish but solid mount.
I think that is an excellent adaptation of two pieces not really meant to go together. Good job!
09-08-2013, 05:10 PM
CB4ME_imp Offline
Threads: 183
Buffalohead asked me to post these 3 picture's from Mike's bike.
Mike took the clean and simple approach as you can see.
[Image: b3a5cf4a8bfe476da273bf3c09a25fae.jpg]
[Image: f110e9bb256aca94718235632802eb50.jpg]
[Image: be5a4636edff5b90c2892c526f0d2cc4.jpg]
The Jardine sissybar comes with two M10x1.5x25 bolts but it appears Mike used longer 3/8" bolts instead. Notice he slightly bent the bolts where they meet the sissybar.
Very nice!
09-11-2013, 07:59 AM
  Backrest available Whit_imp 3 416 06-20-2024, 03:44 AM
  T Rex backrest jeffmazz_imp 7 740 09-16-2021, 06:09 AM
Last Post: skenzie1340_imp
  Sissybar Tony.Robbo1982_imp 0 234 01-24-2021, 04:37 AM
Last Post: Tony.Robbo1982_imp
  small passenger backrest CB1100 ex 2015 - with original Honda grill. Alfgaxatico_imp 3 384 11-24-2020, 06:14 PM
  Backrest? V65CigarFly_imp 22 1,653 04-09-2020, 10:49 PM
Last Post: mdharne_imp
  Backrest. Hardhead_imp 4 471 04-08-2020, 04:23 AM
Last Post: Hardhead_imp
  LED TURN INDICATORS - addition & sharing info peterbaron 5 747 12-08-2019, 09:28 AM
  Corbin aftermarket backrest jdinaz_imp 8 817 04-19-2019, 12:26 AM
  CB1100 Backrest Project metalmaven_imp 64 5,127 03-14-2019, 10:56 AM
  Affordable passenger backrest options? Rebel73_imp 8 674 02-09-2016, 04:33 AM
Last Post: Rebel73_imp
