Ohlins
Guth_imp Offline
Threads: 125
RE: Ohlins
(06-13-2013, 09:49 PM)OZZY_imp Wrote:
(06-12-2013, 10:49 PM)darmahman_imp Wrote: Personally Ozzie, I have never found a Japanese shock on a non racing bike to be worth a crap. First off they are built to a price point and second, my fat ass is not taken into account when they are built. ( I don't expect it)
It is easy to determine if a shock will work for you just by pushing it fairly hard around a few good bumpy turns. If it is controlled and the pucker factor stays low, then it is probably OK . I found a lot of unwanted movement when I did test the stockers and decided I wanted a good shock for this great bike. Around the same curves with the Ohlins produces no unwanted movement, at least at the speeds I am comfortable with.
Ok for me, agree they are all built to a price point and I guess at the end of the day the shocks were designed for little Japs not fat ass (as you say) Americans or Aussies!
At some point i'll probably update the shocks but at this point I am pretty happy with the stockers. Generally the Honda feels pretty planted on bumpy corners especially compared to the Street Triple, the weight helps I am sure as do the 18 inch wheels.
I'm truly surprised by that statement. Do you still have your Street Triple? Of all of the "modern standards" that one seems to be the pick of the litter.
06-16-2013, 11:22 AM
Joola_imp Offline
Threads: 12
RE: Ohlins
(06-26-2013, 05:59 AM)Ack-CB11_imp Wrote:
(06-26-2013, 05:32 AM)ChipBeck_imp Wrote:
(06-19-2013, 07:03 AM)Ack-CB11_imp Wrote: I asked Superplush about these Ohlins, piggy-back style,
http://www.samurider.com/?p=3453/#itemImage
Sean said they can be made, 1500 for a set.
Check out that swing-arm, nice.
Sean just emailed, mine will be here Tuesday.
Those look like the piggy-back Ohlins that are on the CB1100 that Freddie Spencer is riding in the French video someone posted here a while back.
Chip
Chip
Those are the piggy-back shocks Superplush said are CB1300's with 1100 ends. They not listed yet but can be put together, drop Sean an e-mail.
You guys should get a group buy together. I was in on a few over on ADVrider for my BMW.
[url=http://www.advrider.com/forums/showthread.php?t=237705&page=47]http://www.advrider.com/forums/showthrea...05&page=47
I like that video.
I'd be interested in this.
06-26-2013, 06:02 AM
Huladog_imp Offline
Threads: 23
RE: Ohlins
Chip
Chip
I like that video.
I'd be interested in this. Me, too!
Aloha,
Huladog
06-26-2013, 06:13 AM
darmahman_imp Offline
Threads: 11
RE: Ohlins
I spoke with James at Superplush about the front end. He talked like he would need to do some research and maybe a doner bike to develop.
Racetech might be quicker. it would probably involve springs and Gold cartridge emulators for starters.
06-26-2013, 07:30 AM
Huladog_imp Offline
Threads: 23
RE: Ohlins
(06-26-2013, 07:30 AM)darmahman_imp Wrote: I spoke with James at Superplush about the front end. He talked like he would need to do some research and maybe a doner bike to develop.
I had shot Racetech and Ricor the same questions if they had applications for our bike, no responses so far.
Aloha,
Huladog
06-26-2013, 09:35 AM
ChipBeck_imp Offline
Threads: 29
RE: Ohlin's Installed
(06-25-2013, 11:25 PM)Ack-CB11_imp Wrote: Happy to report the Ohlin’s are installed. Last night I figured out this was my 7th suspension set-up from them, first twin shock and first for the street, all dirt and track before. The stockers must not do too much because this is by far the biggest change I’ve felt right out of the box, as far as bumps go. Haven’t done anything at speed yet, my own nasty road felt so much better, I was really surprised. Dman hit it by saying “The jarrings of the stock shock are muted”. I’ll say the ride before felt like the rear tire had an extra 20lbs of air in it you can feel the change immediately.
I agree that 10% of the bike cost is a lot of money to throw at it, but I can say the ride has improved at least 75% comfort wise on the slow bumpy stuff under 45mph. Just my warped reasoning for spending, but this one IS worth it.
On the darker, side I snapped off one lower shockbolt and threw out my torque wrench. I have a 3/8” digital coming good from 2-37lbs perfect for 15-25lbs mid-range stuff. Drain plugs, shock mounts, all the fragile stuff.
Besides that the install was simple, had to take the muffler off, but nothing to it.
Ohlin shocks = 2 Thumbs Up
Ack,
Would you please post a side photo of your CB11 with your piggyback Ohlin's installed. I'd really like to see it before I order. Did you get yellow or black springs? Maybe a close up shot as well. I think if I'm gonna spend all that money I'll go all the way and get the piggyback version as well. Will I be able to ride like Freddie Spencer then???
Chip
07-07-2013, 05:53 AM
_imp Offline
Threads: 11
RE: Ohlins
Ohlins is awesome, I have one on my FZ8, but the issue is I would like to retain the stepped preload adjuster to set it for two-up more quickly. Racetech can sometimes rebuild stock shocks so I think I shall call them to find out about this option.
07-07-2013, 06:16 AM
kevbroce_imp Offline
Threads: 6
RE: Ohlins
(03-26-2014, 04:15 AM)AzBob_imp Wrote:
(03-06-2014, 05:50 AM)CB4ME_imp Wrote: I think the HyperPro shocks are twice the money of the basic Ohlins HOs, and probably for good reason.
I think you are 100% right, the HypePros show up in Honda's catalog and should definitely fit.
I asked Takashi about both shocks. His reply: "Unfortunately, I can not ship the suspensions if there is gas inside of the suspension. It is the EMS international regulation."
That doesn't sound right. The gas is nitrogen. The same stuff 78% of the air we breathe is composed of.
I imagine it's because the gas is pressurized.
03-26-2014, 04:45 AM
Red Mist_imp Offline
Threads: 12
RE: Ohlins
(06-12-2013, 01:12 PM)Bonafide_imp Wrote:
(06-12-2013, 10:23 AM)darmahman_imp Wrote: Adj. for preload, comp. and rebound. Same length. I bought from James @ super plush suspensions in CA. They were ~ $1130 inc. shipping. Here is a link to the desc. of the shock:
http://www.ohlins.com/Our-products-new/M...absorbers/
This is the only shock available from Ohlins. I asked to have a black spring instead of the traditional yellow.
(06-12-2013, 09:52 AM)Guth_imp Wrote: Just a few questions:
What adjustments other than preload do these allow for?
Length the same as stock?
Where puchased/cost?
Not calling you a liar .. but I had "Jerry" from Ohlins try to sell me a set of HO 414's - but priced at $1530.00 .. nah, I'll pass. I want my bike to handle better - North Georgia/TN/NC mountains can really push your suspension if you're an aggressive rider (like me). Very cool shock, but not worth the price (to me) .. they have adjustable length to add 8mm or subtract 2mm (373mm/362mm) .. and have compression & rebound adjusters & a ride height adjuster.
Not calling you a liar .. but I had "Jerry" from Ohlins try to sell me a set of HO 414's - but priced at $1530.00 .. nah, I'll pass. I want my bike to handle better - North Georgia/TN/NC mountains can really push your suspension if you're an aggressive rider (like me). Very cool shock, but not worth the price (to me) .. they have adjustable length to add 8mm or subtract 2mm (373mm/362mm) .. and have compression & rebound adjusters & a ride height adjuster. Jerry is cool. I've dealt with him before. Ohlins does in fact offer more than one type of shock for the CB1100, we can get the $1500 version with the piggyback reservoir, too; in fact I believe one of our members installed them on his bike.
For most riders the top-of-the-line isn't going to offer anything that we can use, though. $1100 is about right for that modification. The bike certainly can benefit from better suspension but somehow I've come to terms with mine as it is.
I imagine it's because the gas is pressurized. Yes, of course. Takashi is right. Shipping compressed gases on airplanes is regulated, he probably doesn't want to deal with it. But the gas can be released and the shock recharged by any qualified technician.
(03-04-2014, 09:36 AM)lackskill_imp Wrote:
(03-04-2014, 03:17 AM)xpacpal1x_imp Wrote: So, is there a verdict on the stock CB1100 front shocks? Rider weight (me) is 193lbs, plus gear, if that matters. I have Ohlins HO-010 rear shocks on order...but waiting extra long for the chrome springs to arrive from Europe...all this time is making me think ahead to the eventuality that I will soon be looking to improve the front shocks. Has anyone modified the CB1100 front shocks? If so, what aftermarket parts did you use? I'm planning on self-installing the rear shocks...modifications to the front appear more complex...please advise on what's involved to modify front shocks...I am not a motorcycle expert.
I believe the front suspension really only consists of a couple springs, some oil, and some sort of diaphragm that controls the flow of the oil. I've seen suggestions of changing the weight of the oil in the front shock on other bikes, and there were also diaphragms that change the dynamics of the fluid control as well.
I'm sure someone with actual knowledge will come along soon.
That would be an orifice. A diaphragm is for birth control.
04-01-2014, 04:11 PM
xpacpal1x_imp Offline
Threads: 4
RE: Ohlins
Ohlins installed yesterday. I simply can't imagine doing it without removing the exhaust. Also, the stock shocks, particularly the bottom, take some back and forth motion to get them removed. Finally, I used a few careful rubber mallet taps to get the new ones on. Otherwise, it was easy and without incident.
On reviewing the results, I seem to notice an increment of additional stability and less chatter from the rear. In fact, as some have suggested, putting better shocks on the rear seems to highten the sensation of chatter coming from the front shocks. I'd say the improvement is incremental, just like each of my other performance-oriented modifications (Staintune, Superbrace, Powercommander, Type II bars) and I suppose these all add up to produce a material improvement in performance and responsiveness. It would be interesting to compare my bike as modified to a bone stock model.
I put a lot of miles on the bike yesterday, most of it away from twisty canyon roads, so my most defining feeling yesterday was fatigue rather than amazement at the new ride provided by the Ohlins. I probably should have stayed in the canyons and put more twisty miles on the Ohlins...then I'd have a more definitive view of their performance. However, without a doubt, the Ohlins with chrome springs look nice and complement the original stock look.
Unfortunately, I didn't ride immediately prior to swapping out the shocks and then go ride again to get the best A/B comparison. While swapping out the shocks, I also tightened my chain for the first time (I'm at something like 5,500-6,000 miles)...chain measured right at 1.4 inches and it required only 1/2 turn of the adjuster screws (a complete turn was too much and I had to back off 1/2 turn). So, my first ride with the Ohlins was also done with a nice tight chain.
As you may know, this model of Ohlin doesn't allow adjustment for compression and I suspect I might have been happier with a more adjustable shock. I am concerned that the white rubber grommet reaches to within one inch of the bottom of the shock...I wonder if this means the shock is too close to bottoming out. Please advise if you have any opinion on this.
04-03-2014, 11:08 PM
  Öhlins front fork Yama_imp 4 397 06-28-2023, 09:43 AM
  Ohlins shocks for 2017 Houtman_imp 27 1,625 11-29-2018, 02:50 AM
Last Post: nhawk7504_imp
  Ohlins HO 239 twin shocks: Anyone use them? Ulvetanna_imp 6 590 11-01-2016, 03:37 PM
Last Post: Ulvetanna_imp
  Score! Ohlins HO-010 shocks for $550 Huladog_imp 21 1,254 01-03-2016, 07:11 AM
Last Post: wiredgeorge_imp
  Ohlins for CB1100 mjezek_imp 5 434 03-03-2015, 10:08 PM
Last Post: CB4ME_imp
  Ohlins Piggy-backs Installed Mikey350D_imp 14 894 08-28-2013, 10:10 AM
Last Post: silascopathic_imp
