You can't do that, Panier install
kennyw
Road warrior
I was going to design and build my own brackets and use ammo cans but these came up for a good price and I couldn't pass them up. However, they are not designed to work with the Honda rack. But I am not easily deterred either.
After a little fiddling I was able to mount the brackets by replacing the rear spacers in the Honda rack hardware.
This is the spacer that made everything fit. 3/4" long.
Nice job Kenny! They look great!
If that spacer is all it takes, you would think the manufacturer could have figured that out and included them.
They are mounted a little tighter to the bike like this and could rub on the rack a little. Nothing bad, but enough that it could make a mark over time on the inside, non visible side.
The rack fitment is also not ideal but it goes together if all 4 bolts are installed loose before tightening anything. The rack then conforms to the spacers when tightened and has plenty of flex to accommodate the needed spacers. I don't expect any issues with it.
Any plans for the turn signals?
I already had them relocated to the license plate.
Good job.
I've also purchased a set of these cases and they should arrive today. I am nervous to see if they will fit with my sissybar and/or my Kimija bar.
Any reason you left the factory grab handle blinker mount pieces on the bike? They aren't doing anything other than wasting weight. I left mine off even with the Kimija grab bar- cleans up the classic look.
If I take them off, I would need to get longer spacers. The rack is wide and intended to go on top of the grab rail with the supplied spacers/hardware.
Looks great, Kenny. A little bummed that you didn't do the ammo cans because then you could have been the guinea pig for what I want to do with my bike. LOL
Great job.
Excellent!
I knew that had to be the case (pun intended). I'll be referencing this thread a bunch during install. I plan to do the same. So simple. A 3/4" spacer!
This modification is probably simpler than scoring that great deal you got on those cases. I lament missing out on the recent used gear sales...Kirk Out
If you need any more pics. Let me know.
I have a few more pics of the finished pannier install.
Hi Chegaman. Welcome to the forum. Pop over to the new members section sometime, introduce yourself and tell us about your bike.
