The great thing about windshield wipers is the thin steel stiffening strips embedded in the rubber. Whether you buy replacement inserts to save a few bucks or just get the entire wiper assembly, keep the hardened steel strips; they're great to have around the garage.
So far I've used them:
To remove handlebar grips: Smooth one end with a file, grab the strip with pliers and shove it under the grip. Lift up and spray WD-40 in the opening, then using pliers work your way around the bar. 30 seconds later you'll be done.
Suspend parts for spray painting.
Pull a rag through new, lower handlebars to remove chips and oil after drilling index holes for controls.
Hold a siphon tube straight by inserting a strip into the tube and crimping the end to keep it there. The $5 siphon from Harbor Freight wanted to curl up inside the tank and not stay down in the liquid.
As brushes in my daughter's electric motor project for physics class.
