pekingduck
Just curious Phil. You mentioned the problem occurred after the first oil change at 600 miles. Was that when you put on the K&N filter? I see in the video an OEM filter was in place. Was that replaced later?
I would also recommend using a mechanical stethoscope to try and pinpoint the noise source. They're cheap ($4 at Harbor Freight) and very effective.
