From the 2013 Service Manual: The four bolts in the top of the mount are tightened to 15 Ft lb (front ones first). For the 'handlebar lower bolts' it says to tighten securely.
What size are they and I can probably find the general torque specs.
Be careful.
The nut is actually tightening against metal tube inside the rubber mount, that means:
1. you can not tighten the rubber mounts tighter as they are
2. it's quite easy to over-tight and tear off the bolt or thread (believe me )
And finally -- there are self-locking nuts, so better a bit too loose than too tight.
Be careful.
