Top speed
jamboa_imp
Turned. 600 miles. With all the luggage ready for a 4K road trip it only does 110 mph and pulls but 6500 rpms
Pulls 6500 in 5 th? What about 4 th?
So is it rev limited depending on which gear its in? And that limits speed, or is it simply the speed that triggers a fuel or spark cut?
110.......i find that number hard to take...i got into full areo tuck and hit 130 before i backed out of it.
How about the 0 to 60 in 3.2 seconds, that seems more usable to me.
I'll have to scan and post the Cycle World specs when I get a chance.
They should enable all bikes to pull to redline in top gear!
The CB11 was robbed!!:@
But the low end is much more important...
Was a Speed Triple pulling u? :P
Not necessary. With the proper profile, the CB11 could probably reach that speed if dropped from about 5,000 ft. :P
So tell me why are the US bikes speed limited when only capable of low top speeds. As far as I know the only speed limiting here is that production bikes must not exceed 300kph top speed.
we don't know if its just for the USA or if its a Japan thing that they dont remove. Either way there has to be either a lawyer or politician or both involved.
Lol! Here in south Louisiana the only way to acheive 5k ft. is by aviation...
One idea might be that the front tire is too skinny to give 'good enough' braking and/or handling control higher speeds.. 'good enough' is open to interpretation.
People complained loudly about the speed limiter on the Honda Fury. I look at the skinny 21 inch front tire and single disk brake and could see that you're not going to haul that bike down from higher speeds as easily/quickly as a sport bike with proper 17 inch tires and dual disks..
may or may not be a factor with the CB1100..
Gentlemen,
Automobile and motorcycle manufacturers use speed limiting software for a number of reasons. The new Ford GT500 Mustang hard top has speed limited to 205 mph as does the Ford GT. Tire speed rating is the reason for that #. But the GT500 convertable is limited to 155, and that # is because of very turbulant aerodynamics with the top down. The Bugatti Veyron convertable severely limits top speed with its top down for the same reason. The bolt upright seating position of the CB1100 combined with the lack of a fairing makes for pretty ugly aerodynamics. Makers dont assume that a rider will tuck low over the tank to clean up the aero profile, they know that some riders will pin the throttle and hang on while sitting straight up. So the limiter was set at 110. But it's only software and you can change it with a re-flash of the bikes ECM. I suspect that 95% of buyers including me couldn't care less about going 110+ mph on this bike. If I was looking for that I would have bought a V-Max or Hayabusa. Cheers.
Chip
Actually, we do know. Vehicles (two wheel and four wheel) sold in the Japanese domestic market are all speed limited to a maximum of 180 kph (roughly 112 mph). Originally the CB1100 was a Japan-only bike (followed shortly by Australian availablity). Honda simply chose not to bother removing the speed limit software on the export models. They probably figured that their target market (mostly older folks) wouldn't care that much and they wouldn't lose sales because of it.
ChipBeck_imp said:
Gentlemen,
Chip
Interesting. I would have thought the problem would be with the top up. At high speed, lower air pressure above the vehicle causes the top to expand like a balloon, which can lead to detachment.
I recall taking my '69 Mercury ragtop on a speed test back in ye olden days. It had a high compression 429CI V-8 and would really move. At about 130 mph the ragtop was so stretched out that the glue holding the glass rear window to the fabric gave way. The window blew out and shattered on the trunk lid. At the same time, the sudden noise and wind at 130 mph caused me to leave quite a pucker mark in the seat cushion :D
ChipBeck_imp said:
Gentlemen,
Chip
Mystery solved !
While I'm OK with keeping it under 112 mph, I think Honda made a mistake if they thought that Americans in general would be OK with sticking to a rule like that one :-)
Hah! Louisiana ! Heard someone has a CB11 in Thibodaux!
ChipBeck_imp said:
Gentlemen,
Chip
ChipBeck_imp said:
Gentlemen,
Chip
I recall taking my '69 Mercury ragtop on a speed test back in ye olden days. It had a high compression 429CI V-8 and would really move. At about 130 mph the ragtop was so stretched out that the glue holding the glass rear window to the fabric gave way. The window blew out and shattered on the trunk lid. At the same time, the sudden noise and wind at 130 mph caused me to leave quite a pucker mark in the seat cushion :D LOL!
Bruce Hammerson_imp said:
0 to 60 KM/H in 6 seconds. :)
That sounds cool to me.
However, I want to decrease the time it takes to speed up from 0 to 60. How can I achieve that?
Drop a tooth on the front sprocket or go up 3 teeth on the back sprocket. However at normal running speeds you will be turning a higher rpm.
Get a high performance exhaust
Lose some weight
