GoldOxide_imp
Road warrior
Solid tip PB.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Well considering that I found them for 6$ a pop, they are not that expensive. But yes, they are only made for this bike and no otherLakeWylieJoe_imp said:I think the plugs are costly because of the low production quantities involved. Is the CB1100 the only bike these work in? Could be. The long threads to accommodate the oil passages give them a unique form factor, for sure.
I bought the rest of the OEM tool kit from Honda and the spark plug wrench is a good one with a 10mm hex extension on top that will take a box end or socket wrench.
"Under the pants" sir, my CB is a steed. All my bikes were/are male, it's a bro-love, never romantic lolGoldOxide_imp said:Great show pics Tod. Forum gets a clearer idea of what's under the skirt.
I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmAlfgaxatico_imp said:My friend ; how many time/kilómeters was from the last change ????
I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmtod.branko_imp said:I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmAlfgaxatico_imp said:My friend ; how many time/kilómeters was from the last change ????
'14 CB1100 STD 5 speed
I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmThe ferret_imp said:I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmtod.branko_imp said:I don't think the plugs were ever changed. They are not bad, just rusty as the bike has been sitting for a while, outdoors I suspect. Current ODO is around 13000kmAlfgaxatico_imp said:My friend ; how many time/kilómeters was from the last change ????
I've replaced my plugs on my CB1100 twice, each time at around 40,000 KM's (25,000 mi)
I currently have 36,000 miles (58,000 kms ) on the plugs on my FJR and they will be changed next month
@todtod.branko_imp said:Yup, thanks, all done, I removed the tank for sake of it, as it turns out I even had a special tool![]()
Anyhow, thank you for the tip, I actually only disconnected the quick connector and turned the tank around counterclockwise on the seat.
Air element was a hassle, stuff that is under my right side cover looks nothing like the workshop manual picture. Off to put in fork gaters. That's for a different thread tho![]()
Extremely dusty and humidmax_imp said:Good call Tod, would have done the same when my plugs looked like that, saltspray has a bad effect on these, mine have a little corrosion but are still ok at 40.000k.
Interesting the airfilter, do you find it dusty in the Emirates?
Nice clear pictures too, thanks mate
@todj3gq_imp said:@todtod.branko_imp said:Yup, thanks, all done, I removed the tank for sake of it, as it turns out I even had a special tool![]()
Any chance you could make a little sketch on "turning the tank ... on the seat" ? (thanks for the nice pictures !)
This looks like the start of sumthin' big.tod.branko_imp said:Extremely dusty and humidmax_imp said:Good call Tod, would have done the same when my plugs looked like that, saltspray has a bad effect on these, mine have a little corrosion but are still ok at 40.000k.
Nice clear pictures too, thanks mate@todj3gq_imp said:@todtod.branko_imp said:Yup, thanks, all done, I removed the tank for sake of it, as it turns out I even had a special tool![]()
Any chance you could make a little sketch on "turning the tank ... on the seat" ? (thanks for the nice pictures !) And sure, I will be happy to. Hope it helps.![]()
Dang. No clay model coming?tod.branko_imp said:It was a 30 seconds sketch. I guess the paper is transparent, not an issue, no top secret stuff there![]()
