RPM/SPEED in 6th GEAR question
peterbaron
Road warrior
Need to know the EXACT RPM in 6th gear at 62mil/h = (100km/h), please.
Please state the year of your CB.
Thanks to all who responded.
gearingcommander.com
2014 6 speed std gearing 18t countershaft sprocket, 40 tooth rear sprocket. 62.7 mph=2900 rpm in 6th gear.
Paul.
My CB1100 EX changes speed up and down hills in 6th.
I assume the RPM would alter slightly as well.
I find very little difference in RPM between 5th and 6th at 60 MPH.
Although there must be because the motor is quieter in 6th.
I prefer 5th because it hold better up hills, and slows better for tight cornering.
I wondered if I was wasting gas opening the throttle in 6th to climb hills.
So now I only use it on busy highways at speeds over 60 MPH.
Despite using 5th most of the day on twisty and hilly back roads, I still get 60 miles per Imperial gallon.
My knee dragging days are far behind me, but I still like to sweep through corners.
Now it is how smoothly I can do it, rather than how fast.
Paul.
Paul.
Hi,
What was the original sprockets set up... or this is stock 18/40 ???
Thanks
Paul.
Paul.
Hi,
Thanks
Paul. stock bike drive train= , std 160/60-18 rear tire, std 40tooth rear sprocket, std 18 tooth counter shaft sprocket =62.7 mph@2900 rpm according to gearingcommander.com. you may want to run other programs.
Hi,
Thanks
Paul.
Paul.
Hi,
Thanks
Hi,
Thanks
Hi,
Thanks >>>>.
Perfect and direct answer.
Thanks for your professional feedback Paul
:beerchug:
Peter
