Mixagon_imp
Many of you will have fitted Rlet's and although they are on you will have failed Mr Honda's test and fitted them with the unsightly seams showing and struggled to push them over the ball with oil, soap, blood sweat and tears.
Mr Honda presented the Rlet's to you inside out with a dry fitting in mind and left you to ponder and reason on the task ahead of you.
If the seam is to go on the inside what better way than to offer up the Rlet ball to the lever ball and just gently slide ball over ball thus turning the Rlet the correct way with the action and hiding the seam inside.
The small hole in the ball is not needed and is just there to confuse.
The larger lever hole finally still needs to go over the lever ball and Rlet ball together but assist the tightness just turn the lever sleeve inside out before fitting starts ( see piccy)
[/img]
This way of course may be wrong but the force was showing me the way and has now put doubt in others minds to as to where the seams should be...
Inside or outside the choice is yours but RS owners the seamless fuel tank could be a clue ?
