Right Crankcase Cover missing from service manual?
bflint
Been there
I can't find anything in the 2013/14 OEM CB1100/A/SA Service Manual that references how to remove (or install) the Right Crankcase Cover (next to the Clutch Cover).  All I can find is references to the timing hole plug that is screwed into the cover.  The other left side and right side aluminum covers all show pics on where the liquid gasket should be laid out on both the engine block and the cover.  Anything to do with the Right Crankcase cover and its' internally mounted ignition pulse generator seem to be MIA from the manual.  Thoughts? :)
That should be in the ignition section regarding removal of the CKP sensor, chapter 17-9 in the 2013-2017 manual.
Spot on Mr Peking D !   Thanks !
