Repair manual for 2017 RS
TheLegend
First service completed
Can somebody please help me with a Repair/Service Manual for a 2017 Honda CB 1100 RS SC 78 in English? Can I find it somewhere for download or so? Thank you!
I purchased the actual manual for $175 USD from an eBay Seller. It was a few hundred pages and published by Honda. Great manual but not available in PDF form.
To the best of my knowledge, there is not an official Digital Honda Service manual available for download on the Internet.
The digital version of the owners manual can be downloaded from here:
https://2rom-prd-data.hondamotopub.com/om/HPI/CB1100EX/2018/CB1100EX_32MGC6520_0.pdf
Hope the Owners Manual will help.
If you do find a credible, digital version of the service manual for sale, please update this post. David
Hope the Owner's Manual will help.
I need it bad now for the valve clearance check, distribution chain and others, in order to try and solve that knocking and vibrations. This bike is not known here yet and the mecanic need that data. Thank you!
I need it bad now for the valve clearance check, distribution chain and others, in order to try and solve that knocking and vibrations. This bike is not known here yet and the mechanic need that data. Thank you!
When I return home, I will look up the specs in my manual and send you a few pictures to share with your mechanics. More to follow in 8 hours when I finish my shift at work. David
I checked my manual and the material contained is Copyright Protected. Honda Motor Company, Ltd. owns the Copyright. I am unable to reproduce any part of it. I can share that Chapter 3 (Maintenance) and Chapter 7 (Cylinder Heads/Valves) would most likely provide any competent mechanic the information required to properly diagnose and correct the issue you face.
This manual can be purchased on eBay and shipped from the United States to most other countries. See link:
https://ebay.us/m/pIpKZA
The seller has sold over 50,000 items and has earned the highest rating possible on eBay. Hope this info helps. David
Thank you very much, if you please send me some photos with valve clearance and arround cylinder head insides; hope I will solve my problems one day!  :thumbsup:
Sadly, Copyright Law is not a best-efforts basis. We must follow it on the Forum. Otherwise, we could be found in breach and the Forum could be taken down and I could be fined.
What I can do is share with you what I did when I chekced the valves on my 2017 CB1100EX. It is my understanding that the differences between an EX and RS are primarily frame, suspension, tire, and brake related. A competent mechanic should be able to mature what I did and render a great adjustment for you. Note that there are professional mechanics on the Forum who do better work than me, they just do not enjoy the work as much as I do. :)
In summary, I
  1. Removed the cylinder head cover, cam-chain tension bolt, and sealing washer
  2. Aligned the “T” mark on the CKP sensor rote with an index mark on the right crankcase cover
  3. Confirmed that the timing marks on the CAM sprockets were flush with the cylinder head surface
  4. Used a feeler gauge between the vale lifter and cam lobe to make sure that the intake clearance was within tolerance ((Intake: 0.15 ± 0.03 mm; (0.006 ± 0.0001 in) for the No 1 and No 3 cylinders
  5. Turned the crankshaft clockwise 180 degrees, and aligned the CKP sensor rotor with the index mark, and checked cylinders  2 and 4 to make sure their intake clearance was within tolerance ((IN: 0.15 ± 0.03 mm; (0.006 ± 0.0001 in)
  6. I checked the exhaust valve clears similarly. The tolerance for the exhaust valves is ((Exhaust: 0.28 ± 0.03 mm; (0.011 ± 0.0001 in) for a 2017 CB1100EX.
My motorcycle had 6,800 miles on the clock when I performed this check. The valve clearances were absolutely perfect. I did the check more as a training exercise than anything else.
Hope this helps and I invite other Members of the Forum to augment this post if my summary merits further details or corrections.
If you need more information, you can reach out to Honda on the following site:
https://powersports.honda.com/contact-us
I contacted them once in 20 years. However, their response was swift and supportive. I believe if you explain to them your unique situation, they may be able to send you any additional information required to get your motorcycle where you want it to be.
I hope this helps. David
Wish you good luck with proper diagnosis before digging in!!!
This bike was in a foreign country before you bought it?
Does it run ok besides the noise issue???
You also promised to provide a video about this issue..??
In summary, I
Thank you very much for your care, elaborate answer and technical details, really appreciate!  :thumbsup:
At this moment I really feel hopeless, I have no diagnose yet, the Honda RS specialists here are almost zero(no Oficial reprezentative, no repair/diagnose experience at all); the mechanics I know, are not aware of this RS/EX type and letting them blindly open the engine to see "what's inside"... is not an option for me. I feel like this season is fu..ed up, it came to my mind about selling it! :(
A 2017 Honda CB1100RS is one of the most sought after motorcycles within the CB1100 community. I hope you can find a way forward where you can keep it. This video link below provides more data about valve adjustments on motorcycles which are similar to your RS:
Hope this helps. Please stay connected to the Forum if you can find a way to keep your RS! David
Yes, I bought it from Germany, the service book is ok till 8.800 km(now 10.000 Km). Buying it in December I didn't have the time to ride it properly but, since 3-4 months I started to feel vibrations(over 3200 rpm) and, after the engine is well wormed up I've noticed that knocking(in idle) in the upper part of the engine/cylinder head somewhere under the lid of the camshaft/valve are. In plus when I moderate accelerate(at low speed) it jerks, when decelerates is very blunt with shocks. In rest when I ride it at speed/highway it runs OK but with that high pitch vibrations over 3.2-3.5000 rpm, very frustrating. I am really worried about that knocking, thinking at what can happen inside the engine... something is wrong, like a misaligned shaft or a broken something, or... I don't know.
I've tried several time to upload a small video(MP 4-13.5 MB) but with no succes, maybe somebody can tell me how and what format has to be.
This is a youtube link that I made with the knocking sound, hope it works:
Thank you again! I'm talking now about valve clearance because if I still open the engine I have to do valve check too but, this will not solve my knocking problem which my good sense says that is not a valve knocking(which is high pitch) this one has a deeper cause... :(
PS: how can I upload a video MP4-13.5 MB because I can't do it, it seems to download but in the end... nothing
You can't upload a file that size to the forum, TheLegend. You'll have to upload it to a site that hosts videos — YouTube, Imgur, Vimeo or the like — and provide a link to it.
Has it always made that noise?
To me that sounds like injector noise...
When I got my CB I noticed the "ticking" noise - especially under hard acceleration from low speed but goes away as you let of the throttle. Looking through other threads the injectors make a lot of noise especially as the bike has a quiet exhaust and there is no waterjacket around the engine to muffle any noises.
A tip I learned restoring old bikes is to take a wooden dowel and use it as a stethoscope. One end to your ear and one end to suspected noisy areas. This can help narrow down where the noise is coming from and if its a concern at all.
A few questions, my friend. Do not loose your hope. The RS is one of the best motorcycles on the planet, and the Forum has at least two master mechanics that can assist. To balance expectations, you may have to take the leap of faith and allow a certified mechanic to open up the engine. But for now, let’s gather some more information:
When you drive the motorcycle at 10 miles per hour, how does it ride and sound?
When you drive the motorcycle at 30 miles per hour, how does it ride and sound compared to 10 miles per hour?
When you drive the motorcycle at 50 miles per hour (if it is safe to do so), how does it ride and sound compared to 10 miles per hour?
Is there any black exhaust plume at any RPM?
Have you changed the oil? Did you see anything in the oil?
How does the tread wear pattern look on the tires? Is there anything that suggests that either tire is out of round or that one of the tires is out of balance?
Do you have a Honda Motorcycle Dealer within commuting distance to your home?
Can you trailer your motorcycle or have access to a rental place where you can rent a trailer?
My instincts tell me that you have (1) more than one minor issue and (2) they can be fixed easily and relatively inexpensively.
David
David
Dear David,
- The bike generally it rides OK, no misalignment or wobbling, it stays straight, engine goes "round" no misfires or so. When cold no knockings.
- The problem came, doesn't matter the speed, after 3.200-3.500 rpm or more, when strong high pitch vibrations occurs, felled in the handlebar. I ride it even at 140 km/h, the more rpm raise the more vibrations are, and the middle range when you ride the highway is exactly between 3k- 5(6)k rpm. I try several times at 120-140 km/h and pull the clutch(on free), acceleration on idle and at that speed the bike was smooth as butter so, nothing to do with wheels, tires etc. Everything comes from the engine run after 3.200 rpm...  :dodgy:
- No plume/smoke/fog from exhaust at any rpm
- Yes I've changed the oil after I've buy it, from AmsOil 10w40 to Honda 10w30 same problems; the former oil that I rune only ~ 1.000 Km was a little dark but nothing special inside it(like metal/debris etc). I'd tend to believe, if I remember correct, after that AmsOil I recall all this problems begins... but I'm not quite sure, because in spring '25 my first rides where short because of the weather so, not much attention payed.
- Again is not from tires or cyclistics, because e.g. at ~140 km/h and pull the clutch/idle rpm, the bike is very smooth as a normal bike has to be.
- Honda don't have an Oficial Representative in RO, there are only dealers, I was at the biggest one here, they made a kind of check and they declare they don't sell and don't know this bike and engine at all, in short they only can suspect/guess(but they give no clue or a suspicion) and is not OK with me that thing(we open and we will see what's there) I'd like to have a ~ certain diagnose and cause prior opening the engine.
- Tell me please what is your instinct suspicion(nr 1)!? :idea: Let's hope is a minor thing; for me now the knocking thing is more dangerous and warrying then vibrations(or they are linked)
Thank you David! :thumbsup:
David
Dear David,
- Honda don't have an Oficial Representative there are only dealers, I was at the biggest they made a kind of check and they declare they don't sell and don't know this bike and engine at all, in short they only can suspect/guess(but they give no clue or a suspicion) and is not OK with me that thing(we open and we will see what's there) I'd like to have a ~certain diagnose and cause.
Great answers. Much appreciated.
I reached out to PeterBaron, who is one of our best and brightest. He is traveling now but will engage as soon as he is stationary and has proper audio output. Let us digest all the data shared so far and we will send you a thoughtful response.
David
