Release Update: Dark Mode Is Enabled
rdprdp01
Administrator
Please be advised that we have completed the design and development work to allow for “Dark Mode” viewing on CB1100 Forum. That function is controlled by a toggle switch in the User CP profile.
To place your CB1100 Profile into dark mode, access the CB1100 Forum and Login with your credentials:
Click on the User CP link located below the CB1100 Header:
Click on Edit Options and then Select the option in the lower right hand corner of your screen that reads “Would you like to enable dark mode?” and then select Update Options:
Your profile will then be placed into Dark Mode Viewing on the CB1100 Forum:
Apple devices often require a Cache to be cleared for this kind of setting change to be made. If your device does not go into dark mode, clear your browser cache, reboot your device, access the Forum, and login again.
Note on phones, the Responsive Theme we have built assumes you will be viewing the Forum while holding your Phone in a landscape position.
If you wish to return to the default “Light Mode” viewing for the Forum, de-select the Dark Mode option, click on update profile, clear your cache, and restart your device.
Have a great day and be safe on your motorcycle.
David
You don't know the power of the darkside,
You will join us or...
Love it!
Though it does seem that there are some aspects that do not want to switch to the dark side. For example, when you "like" another users post, that like banner stays white and the text all but vanishes. Another example is when posting/replying/etc, the message composition pane appears to stick to the rebel forces ideology. Also, it seems some forum memebrs signature text stays black and becomes hard to read. Not sure if that is old posts only since after I posted this, my signature text appears white, yours however seems to come across black.
Whoops said:
Love it!
if you find anything else, please post it. we will fix it. david
[quote="1973cb750" pid='268679' dateline='1747332024']
mine doesn't change i cleared my cookies and cache
[/QUOTE]
Please reboot your device and try again.
Please let me known if that works.
Thanks,
David
Mostafa and I pushed out an update. For those interested in dark mode, please try again. If you experience a problem or have a suggestion, please post a screen shot and provide a detailed comment. Thanks, everyone.
David
Sample new post following update.
It worked for me. I had to go into my chrome settings and clear the cache to make it work, but it's working.
If you have any suggestions for improving dark mode, please post them so we can act on them. Our developer has to move on to another project. Thank you. David
