White Dog_imp
Been there
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I/m wondering if there is a longer-shafted brake lever that would work on these cycles so that one would not be tempted to rest his foot on the brake pedal.Rboe_imp said:I gotta thank you for posting that picture as it got me motivated to pull out the tablesaw, general collector of crap in the shop. On the tablesaw, forgotten, was a Bosch Laminate Trimmer I picked up for a song and stashed. So it's like Christmas! I even have a job for it on my latest project.
Here you can see how I've bent back the CB1100 brake pedal a bit, the other shot is from the Griso (stock, it has not been modified).
Someday I'd like to put a second bend in the pedal so the foot lever is parallel to the foot peg, but so far it seems to be working just fine. For my feet (not big, but I do have a 36" inseam) it simply sticks out too far.
What could it be? The dealer says the "rotor was warped from the factory" and will be replaced under warranty, but that does not explain to me how a groove is in the rotor all way around and is lower than where the pad rubs.Randy B_imp said:His shows no signs of overheating that I can see. I looks like something other than the brake pads is dragging.
G'day 'Dog,Lord Popgun_imp said:White dog, Is it possible the axle coller is swapped from Left side to right? They are not the same on the part diagram. Just guessing, but strange things happen.
Anyway, I'd let the dealer sort it out. But here is a link to parts diagrams so you can look for yourself:
http://www.partsfish.com/oemparts/a/hon/52f28bf8f870021404ec5a3e/rear-brake-caliper
To look at the axle hardware, change assembly to Rear Wheel.
Whoa, that is serious heat damage! I too have a bent pedal. Differs from yours in that it is bent from the base of the pedal stem, at the attachment collar. You may note that I didn't claim to have bent it myself, and I didnt. I have never had a problem with foot on brake syndrome (unlike foot in mouth syndrome) but I had a right side low side and the pedal was bent slightly inboard. I left it that way as, unless you know, it looks standard.Rboe_imp said:Here is my last disc, you can see the discoloring and the degree to which it warped.
G'day 'Dog,Pterodactyl_imp said:G'day 'Dog,Lord Popgun_imp said:White dog, Is it possible the axle coller is swapped from Left side to right? They are not the same on the part diagram. Just guessing, but strange things happen.
Did you check out Popgun's suggestion? The collars are different thickness left to right. In any case I take it you bought the bike new and under warranty. As Popgun rightly says it should be the dealer's problem, not yours.
Cheers mate
Interesting. So I should expect to see warping on my rotor when it is removed. That may not happen as I gather the shop will have to send the rotor back to Honda as a damaged part in order to get paid. Makes me wonder how my rotor got grooved so quickly.Rboe_imp said:That is because it got heated up and warped while riding. When it cups like you see in my picture it starts to wear against the caliper body. They don't come warped from the factory. If it did you would have noticed the poor slow speed coasting, like moving it out of the garage etc. The dealer should have noted it while moving it around the dealership, like off the crate. Very poor form on their part if it came that way and they didn't catch it. They are selling, but I'm not buying. Moot point since it will be covered.
If you got a chance to look at the back side I'm pretty sure you'd see the discoloration. I was not able to inspect the back side of the first disc, just the out board side and the edge (both edges toasted the black paint off into a white ash).
What is the difference in the collars? Are the in fact interchangeable? Would that cause the calipher to be closer to the rotor? The guy at Dillon's did not have them in stock so he could not do a side by side comparison. :huh:Lord Popgun_imp said:White dog, Is it possible the axle coller is swapped from Left side to right? They are not the same on the part diagram. Just guessing, but strange things happen.
Maybe the calipher is made of a harder metal than the rotor?Rboe_imp said:It starts to hit hard metal on the caliper (I was down on the ground with a flash light, trying to noodle out where she was touching). Metal on metal will groove like that. I checked the caliper on the second install and it did not seem worse for the wear. Go figure.
I am a bit concerned about the pads though. I use the front brakes only about 90% of the time so I don't see the rear pads suffering much wear for a long time.
I've got a MAP gas torch, so I"ve beeb tempted to see if some heat applied on the back side of the warp would make it go straight.![]()
) I had to adjust the pedal height on both shifter and brake too.How did you bend the brake lever? Did you have to heat it? Is the metal soft enough to bend more than what you did to yours?Rboe_imp said:I gotta thank you for posting that picture as it got me motivated to pull out the tablesaw, general collector of crap in the shop. On the tablesaw, forgotten, was a Bosch Laminate Trimmer I picked up for a song and stashed. So it's like Christmas! I even have a job for it on my latest project.
