Oil Poll, hopefully a safe one!
If I was using Dino oil I would probably change between 2500 and 3k. I could go longer but I get board and like changing the oil and it's not too expensive. Now my car on the other hand uses full synthetic and I have no problem going 7k before a change. Theoretically synthetic can go about 7500 to 10k before breaking it down but it does get dirt and sediments in it. So the answer is yes. I also ride pretty hard sometimes so it makes me feel better.
Sent from my SM-T350 using Tapatalk
Just checking that the first oil change is due at 600 miles if I'm reading the book correctly. Ordered 2 gals and 1 qt for 2 oil changes 2 filters and 2 sealing washers. Ordered everything from Cheap Cycle parts.
Honda GN4 10W30 Engine Oil
Item #08C35-A131L01 $19.99 2 $39.98
Item #08C35-A131M01 $5.39 1 $5.39
FILTER, OIL (TOYO ROKI)
Item #15410-MFJ-D01 $9.93 2 $19.86
WASHER, DRAIN PLUG (14MM)
Item #94109-14000 $1.99 2 $3.98
Subtotal: $69.21
Shipping: $24.53
Salestax: $0.00
Order Total: $93.74
Yes, first change at 600 miles. Is part of the first service check. Ferret has a HOW TO on the whole thing in the How-to section. It is not hard.
uscgmac_imp said:
24.53 for shipping. Ouch.
Yep a bit pricy but my option is a 50 mile 1 way drive in the PU so I'll let the brown truck deliver it. At least I'm good for 2 changes.
