peterbaron
Again, I already diagnosed your problem...Gone in 60_imp said:Oops, forgot to put the lid back on my gasoline can.
:Follow along with the video below to see how to install our site as a web app on your home screen.
:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Tev62_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Gone in 60_imp said:I don't know if you guys have seen these, but K&N puts a little nut on the end of their oil filters that makes them very easy to wrench on and off.
I just ordered a case of them.
Then those four friends are to blame, regardless of whether there is a nut on top of the filter, they should of known there is no need to use a tool to overtighten an oil filter. If they didn't know that one wonders what else they might of ballsed up on their bike. You might suspect this is the same crowd who over-tighten the chain to and wonder why the output shaft bearing failed.
If they had bothered to read the K&N packaging it is touted as a "wrench-off" design, nothing to do with fitting it.
If they had bothered to read the K&N packaging it is touted as a "wrench-off" design, nothing to do with fitting it. As cormanus stated i am the only one that works out their bikes and I did the oil changes myself with the supplies they bought. This was on multiple different kinds of bikes. The nuts were faulty multiple times over the last 10 years or so I've had experiencewith them. I used one of those on my subaru when I first got it and had the same exact problem but luckily I could use a strap wrench to get it off because it isn't in a tight little area between pipes like on our bikes.
And yes I know an oil filter just goes on hand tight by hand because with use it will get tighter on its own..
As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Tev62_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Tev62_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Gone in 60_imp said:I don't know if you guys have seen these, but K&N puts a little nut on the end of their oil filters that makes them very easy to wrench on and off.
So are you saying the filters that required a screwdriver to get off were unrelated to the fact there was a nut on top or that the previous installer had used the nut to overtighten them with a tool? I'm not following your argument here? Or are you just saying you are witnessing these filters leak around the nut and it has nothing to do with being overtightened?
OK, fair enough, I can't argue with your experience.mvk24_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Tev62_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I can literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Tev62_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.mvk24_imp said:As mentioned above those are horrible. I cab literally name 4 friends that have a had those nuts strip/twist and had a nightmare shoving screw drivers through the filters to get them off.Gone in 60_imp said:I don't know if you guys have seen these, but K&N puts a little nut on the end of their oil filters that makes them very easy to wrench on and off.
So are you saying the filters that required a screwdriver to get off were unrelated to the fact there was a nut on top or that the previous installer had used the nut to overtighten them with a tool? I'm not following your argument here? Or are you just saying you are witnessing these filters leak around the nut and it has nothing to do with being overtightened? I'm not arguing Tev you asked and I'm telling you my answer. I personally have installed them by hand many times on more than just the CB. And then when I went to Uninstall them by manner of the Nut they weld on for that purpose. . They strip immediately before the filter even turns.
If you want to use K&N filters it doesn't affect me in anyway. I'm just letting you know as others here have stated that the only filters thus far that have given us any problems whether It be leaks or the Nut stripping were K&Ns.
(+1) once a year.Houtman_imp said:I change my oil once a year and always use a new Honda OEM filter , cost are so little and I ride about 4 to 5 thousand miles a year on my bikes.
For me at least, if the bike gets ridden often enough in the winter season, I don't bother with the stabilizer. Never had a problem. Use "brand name" gasoline though, no discount brands. In Canada at least, discount brands have higher than average water content.Nachodaddy_imp said:For those of us who don't put many miles on our machines, like 1,000 or 2,000 or less a year, how often should we be changing our oil? And fuel, for that matter. I use Sta-bil fuel stabilizer in my 1923 Model T Ford and have considered using it in my motorcycle.
Dang. Oil filters are soooooo cheap in the U.S.Yata-Garasu_imp said:I found another oil filter that fits and seems like a sensible match for the CB1100.
The Super Tech MP6607 is the same filter as the ST6607, but the MP6607 has a silicone drain-back valve, while the regular ST6607 has a nitrile rubber drain-back valve.
Since the CB1100 is oil cooled, having a silicone drain-back valve which resists heat better than nitrile rubber makes good sense.
Of course, the Honda filter also has a silicone drain-back valve. But it should be illegal to sell $26 oil filters!
I'm glad there are good alternatives.
https://www.walmart.com/ip/SuperTec...ndai-Kia-Infiniti-Nissan-and-Subaru/868600480
Exactly! If you can get equivalent or superior quality, why pay $26 when you can get essentially the same thing for $6?GoldOxide_imp said:Dang. Oil filters are soooooo cheap in the U.S.Yata-Garasu_imp said:I found another oil filter that fits and seems like a sensible match for the CB1100.
Exactly! If you can get equivalent or superior quality, why pay $26 when you can get essentially the same thing for $6?Yata-Garasu_imp said:Exactly! If you can get equivalent or superior quality, why pay $26 when you can get essentially the same thing for $6?GoldOxide_imp said:Dang. Oil filters are soooooo cheap in the U.S.Yata-Garasu_imp said:I found another oil filter that fits and seems like a sensible match for the CB1100.
Aren't Super Tech products available in Canada and Mexico too? I'm pretty sure they're sold in Mexico too, not sure about Canada.
Ps. If I had a new bike still under warranty, I could see using an OEM filter just to be safe.
My bike has been out of warranty for over 5 years. Honda doesn't need the extra $20 as much as I do!
The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.Nachodaddy_imp said:For those of us who don't put many miles on our machines, like 1,000 or 2,000 or less a year, how often should we be changing our oil? And fuel, for that matter. I use Sta-bil fuel stabilizer in my 1923 Model T Ford and have considered using it in my motorcycle.
The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.mvk24_imp said:The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.Nachodaddy_imp said:For those of us who don't put many miles on our machines, like 1,000 or 2,000 or less a year, how often should we be changing our oil? And fuel, for that matter. I use Sta-bil fuel stabilizer in my 1923 Model T Ford and have considered using it in my motorcycle.
I assume this difference is because a car is generally used year round and a bike gets the winter months off in most regions.
Not really sure why but that's what I usually see reccomended.
The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.Yata-Garasu_imp said:The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.mvk24_imp said:The reccomendation I've always seen was once every season if not meeting the mile requirements for a bike. A car is usually the 3/5k miles or every 6 months.Nachodaddy_imp said:For those of us who don't put many miles on our machines, like 1,000 or 2,000 or less a year, how often should we be changing our oil? And fuel, for that matter. I use Sta-bil fuel stabilizer in my 1923 Model T Ford and have considered using it in my motorcycle.
Not really sure why but that's what I usually see recommended.
Agreed. What I learned was to change dino oil every 3k miles, synthetic oil every 5k miles, or annually, whichever comes first.
That's what I follow, but the mileage numbers are probably kind of random because different engines wear out oil at different rates.
My liquid cooled V-Twin Shadow has a much lower revving engine than the CB1100, and it doesn't get as hot either.
Since the CB1100 is air cooled and generally revs much higher, I think the CB1100 engine is probably much harder on oil than most other bikes. This is just a deduction as I haven't actually done oil testing and compared the used oil between the two bikes.
I use both my bikes for around town driving and I have a car too, so last year I averaged a bit less than 5k miles per vehicle, where in Texas we generally have a year round riding season with a slow month or two.
