Deanohh_imp said:
Get my head right? Love ya man.
I know that wasn't politically correct.But unlike Chris Harris
who loves to use the " F " bomb,it's best to cut to the chase.
Make sure another fellow Motorcylist isn't confused.
I know what I know.A lot of bikers have their preconceived notions
as to what entails a good engine or a good bike.
I remember once using a kinda cheap run down garage to
get new rubber on my Mitsuhushi " Evo ".
The place was really dirty and a mess.But the head garage guy
did his job and ordered the tires and they were there the
next morning,just like he said.I got to talking about tires and
rubber { The " Evo " is a road rally race car for the street }
The garage guy said as if in total belief ... That Rubber is Rubber.
Like there's virtually no difference between tires as to rubber.
Maybe and maybe not.There are compounds added to make
rubber stronger or softer.Tires rely more on components like
thread,ply,sidewall or bead { reinforced with steel wire and
low flexible rubber or not.}
All Oil is not the same.All Oil belief is not the same.Some guys
swear by castor oil.Some Royal Purple,some Amsoil.
Is synthetic better for a motorcycle.Not older models.
Not for break-in.Even though with today's tight tolerances,an
engine shouldn't shear off as much as like 30-40 years ago.
if someone never bothered to ask ... What is this Fungus.?
Where would pencillin be.
I have to just shrug off what I know to be Untruth.
ingobohn_imp said:
Rboe_imp said:
A couple points here. If you change the filter with each oil change the "dirty" oil is not that big of a problem.
Mixing of oils is also not that big of an issue. Oils break down over time, especially in hot air cooled engines, to their base viscosity which is the same for the 10w30 and 10w40 and 10w50 etc. So mixing of oils is a red herring. Any oil in quantity is better than no oil and if you maintain regular maintenance intervals for the bike, sooner when it sees hard service, you can mix brands and weights to your hearts content will little ill effect. But you will get better results using recommended oil.
Naturally, if you stick with one weight and brand of oil it won't take many oil changes and you will have purged your system of any trace of that evil break in oil. I think the more important fact is that you are riding and taking care of your motorcycle. God help you if you don't adjust your chain properly though!
Says Confucius ... eh ?
The Master said, .... ' Have no friends not equal to
yourself '.
Needs to be a Harley motto.
I'm not big on Harley types.They look down upon metrics.
The gall.Just because Willie G finally broke the cruiser
King of the Hill record,set by Honda.Around 2005.
Honda was and still is The King of Motorcycle sales.
Maybe not the Cruiser market.
Since 1959 ,Honda reigned as World's largest motorcycle
manufacturer and 2nd largest in the states.
