Odd Throttle Clicking When Accelerating or Decelerating
codyp1814_imp
New to the forum
Does anyone else notice a clicking sound/feeling in the throttle when it is accelerated 1/4 in, then also when decelerating too?
Only happens when the bike is running and the throttle is moved slowly. I figure it could be something to do with the fuel injection system since it only happens when running? I’ve tried adjusting the throttle cables/positions on housing, lubing cables/housing, and tightening housing to no luck.
Just kind of annoying when riding. Wondering if anyone else has experienced it/mended. 2015 standard model.
Thanks folks.
You can feel a clicking through the throttle grip itself? Does it change in frequency with the speed of the bike? There is a sound that accompanies the clicking feel?
There are two throttle cables (one for positive close as a safety feature) that work the butterflies, in addition to a return spring that works to close the throttles. There is a throttle position sensor on the left side of the throttle body bank to measure the angle of the butterflies, but it has no motors or servos that could introduce a vibration or sound.
I wonder if something is contacting one of the cables along their route and transmitting some vibration. Weird, for sure, that it only happens when the throttle position is changing.
Those cables run through a cutout in the engine heat shield that sits above the cylinder head. Has the heat shield been off for a valve clearance check or something else? I suspect if the cables aren't routed properly, something could be contacting them.
Also check that both cables are captured properly in the little stay hook near the right side of the steering head.
--Joe
--Joe
Bike only has 900 miles on it so nothing has been taken apart, but maybe was put together incorrectly when taken out of the crate. I’ll take a look if I ever pull the tank off. Thank you for you advice.
Thanks folks.
Cody i would check if something is catching on or interfering with the throttle body cable segment on the throttle body, where the cable connects with the round segment when operated against the return spring, sounds like a unique case, and maybe you find that missing socket they lost in the factory......
I figured it would be unique, just my luck haha. Thank you for the tip. I’ll try to see if I can access that without removing the tank. Difficult because it only happens when the engine is operating too.
Any update on this? I just got my RS bike second handed with 1125 kms on the odo. I started to notice exactly the same as Cody's observation.
Please advise if there is any effect on the operation of the machine.
Thank you in advance.
