New silver renthal bars and bar end mirrors
silascopathic_imp
Been there
Hey guys! So I installed new bars today and bar end mirrors. Silver tiniest rise available renthal bars.
Next up should be the aluminum cowling !
Silas,
I've got a couple questions.
1. What is the width of those bars compared to the stock bar? (Not counting the mirrors or bar end weights)
2. Did you have any trouble with your bar controls hitting the gas tank at full lock?
3. Hollow aluminum or solid?
4. Did you have to shim the bars or bar controls to get everything tight when you installed them?
5. Bar vibration the same, better, or worse than stock?
6. (Last one I promise) Your source, model #, and price?
Thanks bro!
Chip
Chip,
725 mm
Nope! none at all :)
hollow but they have a thick wall, 14mm internal diameter
no shimming needed. just had to drill the holes for the controls to lock into. (measure and test prior to drilling)
Vibration is a bit better to be honest. My stance has changed so I put more weight on my hands (because I'm leaning forward more, which I love)
They are Renthal Road Ultra Low Bars. I paid $52 for them. They come in satin aluminum (what I have), satin gold ( another member on here has them) and black ( not sure if they are satin on gloss)
Part # 758-01
I got them from Amazon.com Search for Renthal Ultra Low Road Bars
I really like what you have done. What mirrors are those and where did you buy them?
Thanks.
thank you! those mirrors i found on ebay. Just search for bar end mirrors. You will eventually find these. they come in chrome too. Due to the internal diameter of the renthal bars i had to alter the mechanism that allows the mirrors to fit inside the bars. The mirrors come with a screw and a flexible plastic washer thing that as you tighten the mount inside the bars the mount actually stays in place. The plastic washer doesn't fit inside. I has to replace it with a piece of rubber hose. It did the trick and those mirrors work wonderfully!
Did you try flipping the risers around to move the bars forward slightly? I've heard it can be done, but haven't seen/tried it yet. Probably wouldn't work for me anyway because I'm short, but i've considered it.
i havent but that is an interesting thought! perhaps i'll give it a shot!
Hi Silas,
I'm really interested in see how the bike looks with this bars but I cannot see your pics, no idea why.
Please can you send it again, I'm planning to change mines as well but didn't decide yet between low and ultralow.
Regards,
Jose
Chip,
725 mm
Part # 758-01
wow, are you sure?
Stock width on the Honda website says 835mm, thats a 110 mm difference :-/
So its 55mm = 5,5cm less width on each side?
http://flemish.honda.be/content/motorfietsen/modelen_cb1100_abs_technische_gegevens_prijzen.php
Further question about your bars, do you sit more upright or more agressive with these Ultra Low Renthal bars?
Like what is the difference in rise between your bar and the stock bars?
