low oil pressure light kaput
norton1974_imp
First service completed
hello.my 2014 cb1100 low oil pressure red light does not light.
ground from switch to gauge checks fine.
i have illumination for both gauges,
does the gauge light and the low op light use the same hot lead?
if not which color wire supplys the power for light.
the ign wire black/brown is my guess
thank you for your help
That is my understanding as well, 1974.
The lights used for oil pressure etc. are led's, they last forever which is why they are so suitable for this job.
Led's run on 3 volts and so need a resistor in series to run on higher voltages.
Could be there is a bad soldering joint inside the cluster which prevents the led from operating,
and a link to a german video with a 2013 instrument cluster, this is not your type but it may give you an idea what to expect for the repair;
And how it's put together;
https://www.partsfish.com/oemparts/a/hon/52f28be9f870021404ec5a33/meter
Have you checked that the oil switch opens with the engine running and the blue led lights up with the high beam?
1973cb750_imp said:
also leds do not last forever especial poorly manufactured leds witch are about all you can get now days
More often than not, LED "failure" is due to poor power supply characteristics, that is, the power circuitry is problematic and the LED is fine.
More often than not, LED "failure" is due to poor power supply characteristics, that is, the power circuitry is problematic and the LED is fine. that is true but lately since the "chip" shortage i have seen alot of failures even in high end equipment
Hopefully the world can flush and turn that nonsense around.
One more thing; what is the volt meter reading between the DISCONNECTED oil pressure switch wire and ground with the ignition switch in run?
i've always checked those with continuity cb doesn't use a ground interrupted switch for the dummy light ?
Absolutely right 73, that's what we normally do, check continuity with an appropriate load like a 12v light.
Just this time i thought as a second test it may be an idea to disconnect the oil pressure switch terminal and see what is happening at the led's supply side, if it was open or if some supply is still present, just an idea.
