differences between the 2013 std and 2014 dlx
(in no particular order)
1 Silver motor vs black
2 Silver wheels vs black with silver edges
3 4 into 2 exhaust vs 4 into 1
4 Chrome waterfall head pipes vs snaky stainless head pipes
5 ABS standard
6 Taller, patterned seat vs plain
7 Polished master cylinder covers for clutch and front brake vs black
8 Chrome bar ends vs black
9 Polished top triple tree vs painted
10 Headlight raised an inch
11 Horns raised an inch
12 Smaller turn signals
13 Front sprocket cover now aluminum instead of plastic
14 Color matched side covers instead of silver
15 Side covers wrap around frame vs sotting inside of frame
16 4.6 fuel tank vs 3.9
17 New speedo limited to 120 mph
18 New instruments have different patterned faces
19 Digital gear indicator
20 Fuel computer that tells fuel used, ave mpg, fuel remaining
21 Passenger grab rails on a different angle to follow contour of new seat
22 Passenger grab rails polished
23 New left hand switch assy to match other 2014 Hondas ( I put a 13 switch back on mine)
24 Front forks take different amts of oil in each leg (for some reason but its new for 2014)
25 Rear axle size reduced (lower torque required for some reason but it's new for 14)
26 A little easier to do oil change if you want to count that lol
27 570 lbs wet dlx vs 540 lbs wet std ( due to ABS, larger fuel tank, 7/10 gallon more fuel, aluminum vs plastic sprocket cover, and extra exhaust pipe = 30 pounds weight difference)
28 6 speed transmission
29 DLX handlebars 1/2" taller
The 2014 std gets the black treatment applied to the 2013 std, plus the 6 speed trans plus the dlx instruments, gear indicator and trip computer only with black faces.
