Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
downeck_imp said:Life is short man- you want a CB1100 then get one. Read all the advice you're given here and take it in. Be cautious and learn to ride the CB little by little.
2013 CB 1100
There is a LOT of wisdom on this thread. I would concur with the above two suggested starter motorcycles and especially the Suzuki which is the closest to being a bicycle with a motor on it. Few bikes will come up off the kickstand SO easily and that is an indication of easy/forgiveable low speed maneuverability. However, it is a 650 and has some reasonable grunt when called upon. As a bonus, it is belt drive and thus requires no chain maintenance. The Suzuki S40 was formerly known as the Savage and there are plenty of them available used and inexpensive.F800GT_imp said:Welcome !
Riding the CB1100 fast out there on the open road and not crowded is not that hard. It is when you have ride a heavy bike at slow speed then things get more difficult. Knowing how to stop a fast and heavy bike when you encounter a dangerous situation is a different story.
It's hard to ride a CB1100 in crowded areas with cars, pedestrians, dogs, deers, bicyclists ... crossing your path. If you add gravels, blind turns, oil, pot holes, ...
I would suggest to start with something like the Rebel like others have already mentioned or the Suzuki S40 ( http://www.suzukicycles.com/Product Lines/Cycles/Products/Boulevard S40/2017/S40.aspx ) to gain experience, and learn to anticipate dangerous road conditions to avoid them. The Rebel or S40 will be a lot more forgiving.
