Check your state laws first. I suspect that a LEO looking to generate some revenue could hassle you about this product. Virginia has required annual state inspections and they are crazy about this stuff, for example:
"D. Signal device (intention to stop or turn).
1. Signal devices are not required on motorcycles; however, if installed, they must operate and be inspected.
2. Signal lamp lenses installed on the front of the motorcycle shall be amber and be located on each side of the vertical centerline of the motorcycle and as far apart as practicable and not closer than nine inches, measured from the optical centerline of the lamps, and to be located on the same level and not less than 20 inches above the ground level. The optical centerline of the lamp shall not be less than four inches from the retaining ring of the headlamp unit.
3. Signal lamps installed on the rear of the motorcycle shall be red or amber and shall be located on each side of the vertical centerline of the motorcycle as far apart as practicable but not closer than nine inches, measured from the optical centerline of the lens, and shall be located on the same level and not less than 20 inches above the ground level."
This is just a paragraph out of mages and pages regarding the state inspection rules!
