The thought occurred to me the other day on how many different ways there was to skin a cat with a motorcycle. Cars not so much. V twins in various configurations and cylinder angles, Flat sixes, inline 4s, parallel twins, singles, two strokes, 3 cylinders inline, air cooled, water cooled and on and on.
Had a 2003 1200 sportster and had no gripe with the engine at all. 66 hp at the crank and I think 72 ft lbs. It was the rest of the motorcycle I had issues with because it was a rigid mount. Shook like nothing you have ever witnessed. For a lack of a better way to describe the experience it was like buying a new Model A Ford in 2003. Handling and braking sucked. It was not user friendly and would wear you out quickly because of the vibration. The vibration caused all sorts of havoc with loose motor mounts and other stuff constantly needed tightening up. It was imo a poorly engineered motorcycle for its time with a pretty darn good engine. Otherwise it was reliable mechanically.
From the 2003 1200 Sportster to a 2003 CB750 Nighthawk. Talk about night and day literally. Similar weight, size, and power and totally different animals. Its a fair comparison because of those things plus they were both the same year model. The only things on my Honda that are worse than the Sporty are the seat and the stock head light imo. The 750 will out run it in an all out drag race (but not by a ton), out handle it by a ton, out brake it by a ton (and the NH could use better brakes). But, it just superior imo for everyday use and getting from point A to B. The one thing the NH does not have is torque. 45 ft lbs vs 72 or so for the 1200. But the 750 has 75 hp at the crank. The strange thing is from riding it is that I dont notice it all that much but you have to grab a gear or two down to really get it to roll if you have to vs the Sportster you could just roll on the throttle and it was there. The Honda though you can just run through town in high gear at 35 mph and 2500 rpm and you could not do that on the Sporty because the engine would not come up on cam till about 2000-2200. It was lugging below that.
I would love to ride a EFI rubber mount 1200 Sportster but I like what I have so much that I dont think I will ever go back. I just really like how docile this motorcycle is and how it can be fairly quick when called upon and everything about it to me at least is very user friendly and super easy to work on. It suits me and my riding style pretty well. It has its shortcomings for sure but I like how smooth these inline 4s are and the general character of them. Predictable, reliable, easy to ride, easy to work on, and plenty of power when you really need it but do you really ever have enough? I just wish I had a little bit more torque and some better brakes and EFI. Bought this 750 used 11 years old and now have ridden it enough that I finally trust it. I would get on this thing and go anywhere at the drop of a hat.
