Ion lithium batteries
Reminds me of Tootle the Train. :D
MaFiHa_imp said:
Flynrider_imp said:
GoldOxide_imp said:
Rboe_imp said:
Lead acid will not last decades in Phoenix based on my experience. Shorai had a sale last year so I picked one up but it does NOT have an internal circuit for charging. Picked up a L-Ion battery for my go box battery supply (telescope, ham radio etc.) and it DOES have the extra circuitry. Got it from Batteries Plus and Bulbs. No more Shorai for me.
Maybe so. Wet lead acid batteries do need top-up of water and/or acid from time-to-time. Maybe the dryness of the desert-like regions are harsher?
It's not a lack of electrolyte solution, it's mostly the battery chemistry. Lead/acid batteries will accept more charging current as the temperature increases. Charging and discharging at higher ambient temperatures tends to increase the amount of lead sulfate that is deposited on the outer surface of the plates. This premature buildup of corrosion on the plates is what ultimately kills the battery before its time.
MaFiHa_imp said:
Flynrider_imp said:
I'm quite happy with my LI battery. See the thread Cormanus posted above.
In another few weeks my battery will have survived 4 years of regular use here in the desert. I've never had a lead/acid battery go longer than three. The main advantage (for me, and other desert dwellers) is that the LI battery doesn't suffer the short life typical of lead/acid batteries in extreme heat.
I just wish I could get one for my truck and my plane.
OT Would love to see a pic of your plane ;)
On Topic; I have LiIon batteries in two of my Kawa’s since three or four years.
Best thing of it is that they don’t have the problem of loosing acid while warm temperatures and while charging. Also think about when acid level is low and Bike is on the side stand. Then parts of the Anodes (cathodes?) get dry. Also if one put the bike in winter storage you’ll never have the issue of refilling the cells.
AND no rust around the battery compartment.
When the lead battery of my GPX will get weak I also replace it by a
LiIon :biker:
Here you go! When I travel on the CB, I tend to stick to the pavement. This is my off road transportation. :D
LiIon :biker:
Thank you :worship:
I like that "Off Road"-thing :celebrate:
Good one!
