Honda Exhaust Stock LOUDER
After I put a Yoshi (with permanent baffle) on my '14 Standard, I happened to be at a vendor store and a young chick backed in beside me. Her bike sounded like an old pig with a bad cold. I immediately saw her muffler was also a Yoshi and said to her "You removed the baffle, right?" She laughed and said "How did you know?" I have since sold my Yoshi and reinstalled the stock, mostly to get the heat shield back.
At the risk of accelerating global warming or raising the ire of playground monitors everywhere, I've altered my DLX (#100) exhaust to sound less like a Honda Civic. Simply pull the stock slipons off and knock out the washer inside the tube on the end closest the catalytic converter. Better low and mid-range power with no ill effects noted. Results in a low rumble at idle and a quiet growl on acceleration that is overcome by the noise of the wind at about 60 mph. Way better than stock without being obnoxious! Result!!!
G'day and welcome bikesnboats. Sounds like a reasonably simple mod.
I find it to be one of life's cruel ironies that as people get older and their sense of hearing begins to degrade they generally also tend to prefer more peace and quiet. (I believe this has something to do with our diminished ability to "separate the signal from the noise" as we age.) It's hard to pin down what exactly constitutes "loud" (or quiet for that matter) without some level of reference being applied such as how many decibels of sound pressure are being generated when measured from a certain distance.
I didn't really mind that the stock exhaust on my CB1100 was so quiet. It was the tone of the exhaust note that was less than satisfying to my ears. I resolved this by replacing the stock can with a Staintune slip-on. It's the nature of the exhaust note tone that is my primary concern (provided that the sound pressure levels produced are still considered reasonable).
I had an opportunity to obtain a really clean Supertrapp system for my Hawk GT for an amazing price so I bought it. The Supertrapp exhaust is interesting in that you can adjust the exhaust passage (along with making it louder or quieter) by adding or removing disks to the end of the can. Sadly perhaps, I never did bother to install it as I was actually quite happy with the exhaust note of the factory unit.
I certainly wouldn't consider either the factory exhaust on the Hawk GT or the Staintune on the CB1100 to be "loud" exhausts. But again, without some standardized point of reference for comparison, this probably doesn't mean all that much to the next guy (or the person who prefers the nearly silent nature of electric vehicles).
Well, I believe you, that it's louder. However, as the stock exhaust is optimized for the EFI, I wouldn't think, your modification enhanced any power, rather it jeopardized the overall well designed powerdelivery.
Unless you provided real numbers of a dyno run, I guess, that's just wishful thinking. May be, it "sounds" more powerful...
Disclaimer: I'm a German and an engineer. Members of both groups are known, not to believe without a written evidence. :hello:
99% agreed, and I am not German.
The 1% of discrepancy is that I am sure that the original exhaust has been optimised, but the optimising criteria is always a trade-off of different factors and these might not be the same for everyone.
It's about the right trade-off between max power output, power delivery (driveability), noise, emissions, efficiency... and you can't be the best at all of them at the same time.
However, I will stay with what Honda has decided is best for this bike :)
Back in the day, folks used to remove the baffles from their CB750 Fours, the fore runner to our current CB1100s, to get that louder exhaust note. It was a fairly popular practice, until an article came out in a motorcycle magazine cautioning against it, because the engines were designed to run with a certain amount of back pressure provided by the baffles. Of course those were pre ECM days. Now we have fuel injection, and engine performance is controlled by the ECM. When I had Vance & Hines aftermarket straight pipes with quiet baffles installed on my Harley, I had the ECM reprogrammed, tuned to that change in equipment, along with a Dyno, so that all the parts worked together correctly. I can also say that after riding a Harley with a moderately loud exhaust for the past 10 years before I got my CB, I dont think the pipes made me any more noticeable in traffic, unless the people in cars around me had their windows rolled down. As others have pointed out, car manufacturers have been on a mission for many years to make car cabins quiet, and exterior noise canceling. I can also say that I motored the Harley into my neighborhood slowly, so as not to annoy my neighbors, because we motorcyclists do not need any animosity from non cyclists. In fact, I think cyclists being viewed positively by non cyclists both on and off the road is in our best interests. So, for what it is worth, my take on the question is that I like the exhaust as is, and trust that the engineers at Honda designed it the way it is for good reasons. That said, if the exhaust is changed, from my experiences, the bike should be tuned for that change. Additionally, and for the same reasons, simply removing a baffle, or baffles is something I would not feel comfortable with.. To each his own, and these are just my thoughts on the question.
james.jordan1173_imp said:
Hello All.
New to the forum. So hello! out there!
Just bought my CB1100 and love it. However first mod is exhaust. It seems a bit quite and want to increase my presence on the road for safety.
Any mod suggestions to make the exhaust loud?
Thanks!
There's a video floating around comparing the 2014 to the 2017. Here's a few screen captures showing the cross section pipe (2014 bottom of pic, 2017, top of pic)
In either case, there's no easy way to access inside the center section of the exhaust to modify b/c it's all sealed up.
However, on the inlet end, there's a restrictor cone that exists for the 2014 pipe, but not on the 2017 exhaust. Honda simply deleted that cone restrictor part completely for the 2017 pipe.
So, imo, if one wants to increase sound on the 2014, the restrictor part at the inlet end is the part that, if deleted, or the blunt tip is modified/drilled out to open up for more flow, I'd bet the exhaust will sound more throaty and match closer to the 2017 bike.
hi i have just change my muffler on my cb1100 2013 i got a emgo mat black some pipe 1 3/4 od
cut a v in the pipe set muffler on the bike wear i wanted it . bent the pipe with v in it to make the angle
i needed to get muffler tight welded pipe cut then ground down weld sliped pipe end in to muffler weld and ground smooth bent a steel bar for hanger using original location on bike then bent 1/8 steel bar to make bracket for center stand weld to pipe used clamp that came with muffler to attached to cb pipe
looks nice clean job would post photos but dont no how to on this site welded a small heat shield to pipe cost of $65 2 hours of my time think it turned out good nice sound put it on you tube this is link i hope
ps how do you put photos on hear
Its not me but it sounds cool!
lolly, welcome to the forum. The easiest way to post pictures here is to open an Imgur account, load the pictures there, and then paste the BB link into your post here.
It’s the same idea as set out in this thread http://cb1100forum.com/forum/showthread.php?tid=1913
Don’t use Photobucket, though, unless you want to pay a small fortune for the pleasure.
Alternatively, make sure the file size of the photo is less than 250KB and use the attachments feature of the forum.
Yet another alternative if you’re using a smart phone to take pictures is to install Tapatalk and use it to load photos. It does the same thing as Imgur but hosts the photos for you.
Here are his pictures.
well that's certainly different looking. Wonder what the drooling stuff under the pipe is in the third photo?
I wanted mine to sound just a little different. My GL1000 is very quiet, but I wanted the CB to sound a little "sportier". I know there is a thread on this forum, that's where I got the idea. I removed the cover at the rear of the muffler, Std only one. And drilled 6 half inch holes around the tail pipe and reinstalled the cover. It's not really louder, but has a different tone. Has a little bark under load, but totally tolerable at cruise and for those around me. The only downside is that the cover is now discolored like the head pipes, I was thinking about powder coating it black. I have not noticed any drivability/performance change and still get 45-55 mpg.
bigsheep_imp said:
At the Southern Ontario meet I compared stock 2013 exhaust to a staintune, Wyvern, and stock 2017 in a video series. It's in a thread here and on YouTube. It'd be a start, all were done with the same phone, from the same distance in the same environment. Good luck, I toy with the idea of changing the exhaust from time to time but there are leather jackets to collect, track days/bikes to pay for, vacations and excursions to plan and execute, the sound of my exhaust keeps falling lower and lower on the priorities list I may never get to it...
AGREE
I know I want to do it, but in the end just not worth it. They do sound awesome with a louder note though.
