I have used Givi trunks before and really like them. I had one I put 30K miles on a previous Honda Magna cruiser, and then removed that before selling it and installed it on my new daily driver, Suzuki Bandit 1250, where I put another 30K miles on the same unit. That previous Givi had a spring loaded electrical connection that permitted the trunk light to activate along with the bike brake light. It required tapping into the bike brake light circuit so they would both light up. That connector was built into the generic mounting bracket the case attached to. It would have gone farther, but some ditz backed into my parked Bandit knocking it over and damaging the unit. I recall it was a 45L (liter) unit.
I can tell you that once you become accustom to having that kind of storage capacity on your bike, you won't want to live without it. That sized trunk is large enough to swallow two full faced helmets, which is convenient if two up, to not have to carry those around. When solo, or commuting, that size will allow you to carry your laptop case, lunch, and rains. Both Magna and Bandit had after-market racks (Magna was an OEM) that the trunk mounted too.
So, I am a fan of the Italian made Givi’s from positive experience.
So, upon getting the CB, I wanted the same. So off to the internet. Turns out, and perhaps a function of the global economy now, scouring all the major retailers including Bike Bandit, Revzilla, J&P, etc., the cheapest price I could find was actually through Motostorm, an Italian retailer. So I placed the order through them. It shipped from Italy. Was concerned there might be customs or duty, but there were not. I did it in two orders (by mistake), first buying the trunk (GIVI V47NN TECH, $204.79), Givi chrome bike rack specific to the CB1100 (GIVI SR1118, $185.41), and the optional rack that attaches to the top of the trunk (GIVI-E159, $52.73). I mistakenly thought the trunk mounting bracket that attaches the trunk to the bike rack was included with the trunk. It was not. Including $33.13 shipping (from Italy), the total was only $475.95, which was much less than purchased from a US retailer. I crossed fingers on the customs and duty fees (to which there were none). That order was placed on 8/4 and arrived on 8/17 and 8/18 in two boxes via FedEx. Not bad!
It was then I discovered it did not have the mounting kit. Bummer! So back to Motostorm for that: Givi E251 Monokey plate ($ 40.36), and GIVI E134S (which was the optional backrest pad [$ 31.84] while I was there) and had to pay shipping again ($33.13). If I had the hindsight, then I could have ordered the mount (and maybe gotten the backrest “free”) not having to pay shipping twice. The second order was placed 8/18 and arrived 8/26 (yesterday! Now mounted!). That was a pretty quick turn-around that was not much more than some US stuff I recently ordered.
Back to it. So, to me, adding a trunk big enough to provide meaningful capacity, it is difficult to find something that looks great seamlessly. Especially on something like a retro inspired UJM. The Givi V47NN Tech (47 L with CF looking center accent) and nice looking “lights”, is about as good as you can get. It looks aerodynamic, though somewhat bulbous. To me, the goal is to add on the storage that doesn't really suck aesthetically, not trying to “improve” the looks. For certain it won’t. I notice some improvements over the old model, including a larger gasket to keep out the H2O. It should do that well as the gasket is much larger than the previous o-ring style gasket previously. The Monokey plate secured with four bolted brackets I endeavored to spread around the perimeter, driven by the underlying rack structure (where the tubes are).
BTW, the Givi rack itself was a decent quality unit. The chrome was well done and seems triple plated, and substantial. The welds were not the best looking, but fade into the chrome background, especially with the rack covering most of it on top, and the stock handholds hiding substantially the rest on the sides. You remove the existing handholds with turn signals attached, and for the ’13-14 CB, remove the existing handhold bolts that go through the bungee tie-downs, put it on the inside of that next to the subframe, and rebolt it back keeping the bungee tie downs (great!). It was a bit of a pain to get it in place without scratching with only two hands, but I liked the result. There was a whole other page for other years that has the installer doing a different procedure involving more supplied hardware (that was unused for my application). It was substantially cheaper than any price on the Honda OEM units I could find anywhere that was 50% more.
All Givi instructions are pictures only making them mediocre.
Mounting the rack was straightforward with a little jiggering to get it as straight as possible. I chose to have it sit back about 0.5” from being butt up against the rack riser (thinking to add some clearance for the backrest and preserve passenger room). The plate is a grate type structure, and you insert metal square plates with elongate slots (for adjustment) you thread bolts through that go past the chrome rack into the brackets and secured with locking nylon nuts. I snugged them well, but not too tight as the plate is plastic and I did not want it to distort or crack. It is actually a heavy weight thick ABS type plastic.
The rating of this case is 10Kg (22 lbs). That was about what the previous one I had was rated too, but I think there is some margin in there, and I have easily carried at least that without worry. I wouldn’t want to put 50 lbs in there, but less due to concern the rack/trunk would fail as you probably just don’t want that much weight cantilevered off the back of the bike that could impact handling.
I also previously said “lights”, because the 47NN looks like it has them, but they are only lenses with ports that will let out light IF you install the optional LEDs inside the trunk. But, the generic mount does not have that built in spring-loaded connector that transfers the brake circuit to the inside of the trunk. I elected to forgo trying to fit something other than the generic mounting plate, plus it was a pain to splice into the brake light harness previously.
With the plate in place on the rack, it installs easily. It inserts into two forward hooks, and then snaps into place with the aft lock. One key (spare included) can unlock the case with the push of the upper button to pop the lid, or pushing the lower button releases it from the mounting plate. Then you can bring it in (your hotel room) if you want to with all the contents inside, or pop it off if you don’t need it for some sporting riding where it is unneeded (or just to make the bike look better). It looks pretty good without the case attached.
Attaching the rack to the trunk lid was a pain. That rack is a well made anodized aluminum piece and bolts to the lid after you drill four holes. A paper template is provided. No instructions, only pictures. It says to remove a bunch of stuff there is no need to (reviewers on line commented as such and that was true). It was a pain because the provided template taped to the lid appears to not line up with the rack four short legs that angle inward making the holes look too closely spaced. What you have to realize, and this was my fault, it has spacers you insert under the feet that are canted inward, that then makes the template holes be about right. Not realizing this caused me to have to remove the rack 10 times to ream the holes just enough, and fight the fasteners from the inside of the lid to line up without cross-threading. Once finally secured, it looks great. I could see attaching a dry bag with a lightweight tent and bedroll to that lid rack to preserve cargo capacity inside. The backrest was an easy 5 minute affair using the template, but those two bolts had markings inside the base, where the trunk rack did not. It would have made the whole affair of attaching the optional lid rack much easier if they had done the simple same thing on the lid with drill hole markings on the inside for the rack. It would have also allowed slightly undersizing the holes such that the bolts threaded through the lid plastic for additional water resistance, though it should not be an issue given the rubber grommets included with the fastener stackup.
Overall, I like the result and am looking forward to getting years of use from it. Considering the heavy chrome rack of good quality, mounting plate, trunk, and optional top rack and backrest, it seems like a good value for around $550. And it is not fugly as far as bulbous cases go.
