Givi rack for top box.
Nick_imp
First service completed
Looking to fit the Givi rack and plate so I can use my givi top box. On the givi site it says for 2013 cb1100, mine is 2017 model EX. Is there any differance between the 13 and 17 model's at the back were you would fit the rails. Thought I would check before I spend my hard earned.
Thanks nick.
1. I don't think it will fit your 2017 MY due to difference in bolt spacing; 18.5 cm /2013, 2014 vs 20.0 cm/2017.
Our member pekingduck =:beerchug: explains this in his post #3
http://cb1100forum.com/forum/showthread.php?tid=17780&highlight=Rack
2. As to the Givi boxes:
Givi maximizes several different bases, so it is important to combine them together to be able to work with the appropriate Givi box as a set
Top Case Plates
2. Study these links as well.
http://cb1100forum.com/forum/showthread.php?tid=8476&highlight=rear+racks
http://cb1100forum.com/forum/showthread.php?tid=3465&highlight=rear+racks
Givi SR1118 Top Case Rack Honda CB1100 2013-2014 - RevZilla
Wow,thanks for the advise. It's a mine field out there. Will need to study all the links. Why do the bolt centers change through the years,thought it was just the tank that changed. Will try to buy from a dealer near to me Rutland in England.Going to measure bolt centers to check.
Thanks again nick.
Good luck! My Givi boxes are indispensable on my bikes. One of the reasons I treat my CB1100 very carefully is that there seem to be a lot of one-year-only aspects - at least for the three year models that were brought to the U.S. I realize that a lot of stuff on my bike is 2013-specific, and would be difficult to replace.
Nick, something to bear in mind is that Givi makes a universal mount that will likely fit on any rear rack you can find. So, unless you particularly want the Givi rack, you may well have options. Try webike.com and samurider.com.
