lagoje_imp
Running like a top
For some reason these little projects seem to take all day.
Installed the Givi E26 base plate on the Honda rear carrier. That part was fairly smooth, but you have to make sure to leave enough room so you can take the seat off. That makes the base plate hang over the back of the carrier just a tad.
Next came the wiring which took the most time. Had to search other forums to find out which of the 3 honda wires to splice to the 2 Givi wires.
The Honda green/yellow wire (power) goes to Givi Red wire. Honda green wire (ground) goes to Givi blue wire. This is key as polarity matters to the LED.
Leave the Honda brown wire alone.
Had to shave the wires a bit with a sharp knife to ensue they were connected. The in line splicers are a good idea but not great.
