I have a shop manual, but it's over at my other garage, so can't refer to it right away. If you have a minute, would you mind explaining for the suspension illiterate (i.e., myself) the relationship between the binding you're talking about and the fork compression?pechorin75_imp said:I have a shop manual, but it's over at my other garage, so can't refer to it right away. If you have a minute, would you mind explaining for the suspension illiterate (i.e., myself) the relationship between the binding you're talking about and the fork compression?CIP57_imp said:It seems there's binding in the triples, it's a very easy adjustment. I don't have my shop manual so we need someone to chime in here. You need to loosen the triple to relax the forks and get them back into alignment. If i remember correctly you also have to loosen the bolts on the wheel.
Sure, when the bike comes from the factory both fork tubes are in alignment through the upper and lower (brackets) triple trees. My guess is that when the bike was dropped against the wall one of the two fork tubes twisted therefore causing a binding. When this happens they work against themselves and would cause the problem your having. You just need to relax the front end ( loosen everything up )and with compression strokes like you just did will put the front end back into alignment.
