My other hobby is old Cub Cadet tractors. I'm a moderator for a Cub site and you have no idea how many fuel related problems we see. The older stuff was never built for ethanol and it eats fuel lines and carbs. For what ever it's worth I do not use gas with ethanol in any of my small engines. Things like chain saws and weed eaters are the most problematic. This is a link to Pure Gas (no ethanol)
Pure-gas.org - ethanol-free gasoline in the U.S. and Canada
What I do is to go to the station and fill my race jugs with 89 no ethanol. I'd use a higher octane but that's all I can get in my area. Then I fill the bike at home. If I need to gas up on the road I try to only add just what I need to get home. I have some gas that has been in a leaf blower now for over a year and it starts on the 2nd pull. I don't use a stabilizer. If you can't find no ethanol in your area and you are planning on storing for the winter look for a race fuel dealer, expensive but you should be able to get a 5 gal can just to fill the tank for winter. Also a good idea to start it every couple weeks.
Here is an option for storage fuel. Made by Sunoco.
http://www.sunocoracefuels.com/fuel/optima
