postoak_imp
I see the problem! They forgot to install the piston return springs on your Honda.
Oh darn! I’ll make sure to let them knowpostoak_imp said:I see the problem! They forgot to install the piston return springs on your Honda.![]()
Yeah I have no clue. The first owner put 7k miles on it over the first 4 or so years of the bikes life. I put 4K miles on it in 4 months, so I’ve never had the same gas sitting in it for long aside from winter with stabil in it.Flynrider_imp said:I'm inclined to agree that some form of contamination led to the excessive carbon build up on top of the pistons. Who knows when it happened. For all you know, this could be something that started with the previous owner.
The only time I've seen anything like this was an old Kaw 750 twin engine I tore down for a friend. He'd had it stored in the garage for years and would start it up occasionally to "keep the top end oiled". This is generally not a good practice, but to make matters worse, the gasoline in the tank was well over 2 years old and had degraded to the point where it smelled like turpentine. On pulling the head, I found a thick layer of carbon deposits on all of the piston tops and scored cylinder walls.
Oh no this bike was too new and too babied to have that happen. Crazy how so many different scenarios have done this to peoples bikes. Sad sad times. I can’t wait to crawl up in fetal position after I hand the dealer my credit cardbeardyweirdy@me.com_imp said:Hey QUINTtastic, That's a bummer! I unfortunately have a set of pics just like those, not from my CB tho. I had a bike that had it's petrol tank sealed by a previous owner. The newer fuel, with high ethanol and the like, had broken down the sealant and washed it into the engine. Is there any chancy someone could have sealed the tank previously? They are all long shots but could be....
Yeah the bikes manual has stupid low shift points. When I read it I thought “yeah okay honda.. that’s realistic..” (then again this might be the recommendation for all their bikes.PowerDubs_imp said:You hit the nail on the head- babied engines build carbon.
There is a head and pistons on Ebay from a 4k mile motor that is just as black as yours. Go look.
I think a lot of guys would be surprised if they opened their engine.
The bike has a lot of owners that only do 2-3k revs lightly. That will cause carbon buildup.
I'm a firm believer in giving an engine the beans fairly often- italian tune up, to literally blow out / burn off the gunk.
All that being said- I do not think the carbon had anything to do with your valve issue.
And on the bright side- you will be the first guy with the factory honda oversize pistons.
If I remember correctly that is like a whole 8cc.![]()
Hey, yeah I will be using some additives from now on. Although we shouldn’t have to use any additives whatsoever on a 2018 Honda, ya know? As long as we use spec oil and gas, as well as do the proper maintenance.. we SHOULD be good.Jeeves_imp said:
WHAT!!!!, engine pre-diagnosed, taken apart and still has the same issue after repairQUINTtastic_imp said:UPDATE: They replaces the pistons, a valve, some gaskets, and adjusted the balancer. STILL HAS MASSIVE VIBES. Yay
:huh:
max, I think the scouring on the pistons is caused by the splash lubrication(or the lack of it) rather than carbon, probably caused by low oil level and/or low rpms. The scour area is typical for this kind of damage; it is where the pistons "lean" against the cylinder walls when bobbing up and down.max_imp said:Thanks for the nice pictures, as you can tell you have our attention.
As a sympathetic audience we could do with some more information;
does the vibration happen when the engine is stationary and at what revs is it worse?
Is there a noticeable lack of drive and when the engine warms up are all four pipes getting hot at the same pace?
It happened from one second to the other, i wonder if the cylinders are contributing equally or if an injector is not working as it should
Found a picture of another cb1100 cylinder with cleaned pistons in front, notice the scraping on all 4 pistons/cyl's.
(click twice for larger image)
Not sure why pistons all score in the same place and I guess your cylinders were scored deeper?
And looking at where the scoring takes place ( well below the rings ) it makes me wonder if it's not something in the oil that gets splashed up to the cylinder walls that causes this?
I mean how does the carbon get past the rings unnoticed and settles below the rings to scrape away at both parts?
I'm sure we all feel the unbelievable misfortune that happened to you and wish for a fair outcome from Honda.
) I had to keep the rpms down. Fast forward 120 hours, I have trouble starting. When we opened up the top that was exactly what I'd seen.
Definitely not the exercise recommended for a Honda
