Do 2014 side covers fit a 2013?
Frulk_imp
Road warrior
I’m looking to put some red side covers on my 2013 and wondered if the 2014s fit. If that was the case I’d give my local dealer some business and order them there.
Had 2013 and have 2014. Swapped side covers (silver/13 & black/14) to see which set had better look. Had no problem with fitment between models.
No issue with seats, rear OEM rack, SW-Motech side racks, gas tank alone (fuel pump assy had to be transfered) and rear fender with tail lamp either.
Hope this helps.
CDN/ABS bikes.
I installed '14's on my '13 - easy peasy. The red colour IS different but unless someone tells you - and you look very carefully you can't tell.
Assuming by the mention of red covers, that you're referring to the 2014 DLX covers. As was mentioned, they're a slightly different shade of red, but they do fit without modification.
Forum member Joola did this a few years back. Here's his post with a pic :
14 seat and side covers tried on 13
