Flynrider_imp said:
DJS_imp said:
That's the link I always point to when someone asks about chain cleaning products. Keith really took the time and care to make a thorough test of various potential cleaning chemicals.
Riko, he didn't test brake cleaner, but another seemingly innocuous substance, carb cleaner, turned out to have a very bad effect on the O rings tested.
I didnt say I would use carb cleaner, but brake cleaner.
As pointed out even by the AVRIDER test, break cleaner seems to be harmless, it certainly did not show visible harm for the O rings, let alone confirm the malicious consequence I read on boards about the topic.
If brake cleaner was indeed that bad, the "test" would at least show some hints of that.
kmoney_imp said:
Brake cleaner shouldn't hurt rubber, as it's designed not to effect the rubber components in brake systems. That said, that stuff is strong, and I don't know if I would want to spray it on my chain.
it certainly is the best cleaning solution for all kinds of dirt on your chain.
Strong and a clean method since it evaporates in an instance.
The first and only time I used it a few weeks ago, I couldn't believe my eyes
