Center stand mod for Yoshimura system
Razor
Been there
Purchased a Yoshimura full system for my 2014 Std. Left the center stand off because the spring return is in the center versus the side on the 2013 models. Some have cut the adapter plate and made it work. Thought I'd try to reuse the stand by making an extension off the pivot rod & exhaust bracket/hanger.
Here's some pics
Machined a piece that goes into the center stand pivot rod. Welded it to a piece of 1/4" x 3/4" flat stock, bent around in a "U". It'll make more sense later.
Extension piece made from 1/4" x 3/4".
Aluminum spacer. Cut the rubber sleeve. Really tight fit.
Series of photos showing how everything came together
Ingenuity at it's best. Way to go.
Looks like a business opportunity! Maybe a few guys on here will want one.
I sure would if I needed it.
I think this whole thread is a fabrication. :rofl:
i'll be here all week. don't forget to tip your waitresses.
Thanks, plan is to put a few miles and uses on the stand and make adjustments if needed. Then pull the two pieces off, clean them up & powder coat them.
MT, you are correct my friend :D
They look pretty good now. Will look awesome powder coated!
You're killing me EmptySea :)
Exotica1_imp said:
RCVS exhaust comes with a new centerstand stop.
I called Yoshi USA and bought the centerstand stop for my 2014. My stand no longer rests on the swingarm. All is good with the world.
