max
For some time i have puzzled over how the cb1100 " knows " where the stroke order is with only the crank sensor to work from.
Best guess i came up with is; "it feeds only one cylinder and when it fires it registers an even or uneven sequence".
Well i just used an electronic " spanner ", it's a 4 channel automotive oscilloscope "h-scope 402" with a 1 minute plus memory capacity of wave forms.
Connected spark plug no 1 and injectors 1 and 4 to the scope, started the bike and this happened.
The two injectors have a different voltage level selected, no4 is smaller so i can identify it reliably, i used only the two that i could get to easy so there might be another explanation how this works.
You can see exactly when the engine was started by the dip of the green line's voltage as the starter button was operated and the dips are the compression strokes of the cylinders when the starter button is operated.
Injector 1 opened to prime with some fuel, then after 3 more cycles it " guessed " the engine was firing in the right order, rev's were picking up pace and started injecting on all four cylinders.
All done in 0,7 seconds according to the time scale below the graph.
So it appears the sparkies all fire straight away but the ecu determines from the injector "success" if the injection order is the right one as far as i can work it out hence the three " misses " before it's happy and the rev's increase on successful combustion.:biker:
. Common and economical alternative for the hobbyist-type.
